0 Replies Latest reply on Nov 11, 2013 8:28 AM by Ferrarezzi
    links according to the folder where the file is?
    Ferrarezzi Level 1
      I have this script that I found here on this forum and would like to change it so that when you execute it according to relink the file name
      # target illustrator
      linkReplacer function ( ) {
           var = orginalUIL app.userInteractionLevel ;
           app.userInteractionLevel = UserInteractionLevel.DONTDISPLAYALERTS ;
           if ( app.documents.length == 0 ) {
                alert (' Please have an " Illustrator " document open before running this script . ' ) ;
                return;
           Else { }
                docRef = app.activeDocument ;
           defaultFolder var = new Folder ( ' ~ / Desktop ' ) ;
           psdFolder defaultFolder.selectDlg var = ( ' Please select the folder of your replacement files ');
           if ( psdFolder == null) return ;
           with ( docRef ) {
                placedFiles var = new Array ( ) ;
                for (var i = 0; i < placedItems.length : i + +) {
                     placedFiles.push ( placedItems [i]. file.name );
                for (var j = 0 j < placedItems.length j + +) {
                     var replace = new File ( psdFolder.fsName + '/' + placedFiles [ j ] ) ;
                     if ( rePlace.exists ) {
                          placedItems [ j ] . file = Replace ;
                     Else { }
                          alert ( 'File " ' + placedFiles [ j ] + " ' is missing ');
           app.userInteractionLevel = orginalUIL ;
      linkReplacer ();
      for example
      filename > TESTE_0000_CLOSED_01
      link contained in the file > TESTE_0000_INDEX
      link contained in the file folder ( TESTE_0000_CLOSED_01 ) is TESTE_0000_INDEX_01
      after running the file the link is > TESTE_0000_INDEX_01
      I do not know if I was clear is complicated to explain
      when run this script searches the linked item in the folder where it is saved, like that instead he relink the file contained in the folder under the file name
