6 Replies Latest reply on Nov 14, 2013 5:28 PM by Andrew Yoole
    Rendering - what causes this?
      What causes my ramped background to render out like this?
      grab1.jpg This is how it should look
      grab2.jpg...and this is what is happening.
      Previous renders have been fine - I don't know what exactly I did to make it start behaving like this. Am using Media Encoder with a Vimeo preset.
      Any help appreciated.
        • 1. Re: Rendering - what causes this?
          More info appreciated.
          • 2. Re: Rendering - what causes this?
            We can't figure anything out from the images without the rendering info and the system and AE version. It's like asking, "Why is a bananna?"
            • 3. Re: Rendering - what causes this?
              Tim Kurkoski Adobe Employee
              Two questions:
              1) If you render via AE's Render Queue, do you get the right or wrong result?
              2) Is your gradient layer at all transparent or using a blending mode?
              Please also provide the basic info as requested by Szalam and Rick. Might help to post a screenshot of your comp's Timeline layers.
              • 4. Re: Rendering - what causes this?
                johnny_alpha Level 1
                Thank you for your responses.
                Here's my System Info:
                Intel Core 2 Quad CPU 2.33GHz
                8GB RAM
                64 bit Windows 7
                ATI Radeon HD3800 Series
                After Effects CS6 - Version - all up to date
                Rendering as an MP4 using Media Encoder on these settings:
                Preset - Vimeo HD 720p 29.97fps
                Field Order - progressive
                Profile - High
                Level 3.1
                VBR 2 Pass
                Target bitrate AND Max bitrate both set to 5
                This issue appears to be affecting just the background layer which is a solid with a ramped gradient. I've tried redering it seperately as an MP4 and using that in the main comp instead and still get the same problem.
                The comp renders out mostly OK, but in the middle of the comp the background flickers to black and back again. I've rendered it out a few times previously with no problemms but this problem started appearing after I started moving the comp's camera. (this is standard 3d btw, not ray traced. RAM preview is fine. I get the same problem when rendering from within AE. These are my Processing settings:
                • 5. Re: Rendering - what causes this?
                  Dave LaRonde Level 6
                  Turn off multiprocessing for starters.  8 Gigs may sound like a lot, but not for AE.  It'sw quite possible you aren't able to allocate enough memory per processor for the AE task at hand.
                  And you are also leaving ZERO processors for other applications.... which includes things like the operating system.  Not good.
                  • 6. Re: Rendering - what causes this?
                    Andrew Yoole MVP & Adobe Community Professional
                    Thanks for posting all the extra detail.  Can you also post a screengrab of your timeline with any relevant parameters (like opacity and transfer/blend modes) visible?
