1. Re: What is the right CMS for FrameMaker 11 and DITA?
Jim A Owens Nov 12, 2013 6:59 AM (in response to NewUser)A CMS (content management system) is used for storing, retrieving, and managing files. Some CMS products are specialized for DITA. But they don't usually come with the ability to create and edit maps and topics. For that, you need a DITA editor. FrameMaker is a pretty good DITA editor (especially with the DITA-FMx plugin from Leximation).
DITA maps don't need formatting. They're simply organized collections of DITA topics. The topics do need formatting in order to deliver outputs. FrameMaker can format them for print or PDF output, and is exceptionally good for this purpose. It can't directly format DITA for other outputs. For this, FrameMaker and many other products rely on the DITA-OT, which can format DITA for many outputs, such as CHM, Eclipse, or JavaHelp (and also PDF, but without the same power as FrameMaker).
To format the topics for page output, FrameMaker uses an EDD. All DITA topics are formatted using the same EDD, and Frame does this "behind the scenes" so you usually don't have to worry about it (although you can make custom adjustments to the EDD if you want).
If you are using DITA, it's a good idea to install the DITA-OT and get it working with other products. There's a Yahoo group called dita-users where you can get help with this.
As an alternative to the DITA-OT, you might want to look at DITA2Go or DITA4Publishers.
