3 Replies Latest reply on Nov 12, 2013 1:48 PM by gkaiseril
    PDF Form: Multiple Choice sheet that displays a percentage based on answers provided
    majmacpherson
      Hello,
      Im trying to create a form that has 4 multiple choice questions, the answers to each being the values 0,1,2,3,4, 5 or N/A.
      Once answers are given, I'd like the percentage to appear on the form.
      I can't figure out how to do this, as the total fluctuates depending on if the response to one or more questions is "N/A".
      I.e. if the answers were as follows: 4,4,4,4, the percentage would be 80% (16/20).
      However, if the answers were: 4,4,4,N/A, the percentage would also be 80% (12/15) and NOT 60% (12/20).
      I figure its a javascript thing - but alas I do not know Java.
      Help Please!
        • 1. Re: PDF Form: Multiple Choice sheet that displays a percentage based on answers provided
          majmacpherson Level 1
          Also - Im using radio boxees for the multiple choice answers.
          • 2. Re: PDF Form: Multiple Choice sheet that displays a percentage based on answers provided
            This is how I've been able to do it so far....  Let me know if you can think of a simpler way!
            First, I set up the values of the multiple choice answers to be 1,2,3,4,5,6, and an "N/A" response value is 0.
            Then I created a subtotal box with the following custom script to generate a total based on the number of questions that aren't answered with a "N/A".
            (The variable x,y,z,w are for each question.)
            var x=5;
            var y=5;
            var z=5;
            var w=5;
            if (this.getField("b1").value=="0" )
            x = 0;
            if (this.getField("b2").value==0 )
            y = 0;
            if (this.getField("b3").value==0 )
            z = 0;
            if (this.getField("b4").value==0 )
            w = 0;
            event.value = x + y + z + w;
            • 3. Re: PDF Form: Multiple Choice sheet that displays a percentage based on answers provided
              So you want to compute the percentage of the non-"N/A" selections using the count of selected items * 5 as the denominator and then use that value to divide the sum of the values for the non-"N/A" selections.
              Has a default checked value been selected.
              Since the averaging is not just computation of the mean based on the item count, you to create a custom JavaScript calculation.
              var aNames = new Array("Radio Button.0", "Radio Button.1", "Radio Button.2", "Radio Button.3"); // array of field names
              var aValues = new Array();
              var sum = 0;
              var count = 0;
              var oField;
              event.value = "";
              for(i = 0; i < aNames.length; i++) {
              // get values of fields into array;
              oField = this.getField(aNames[i]);
              if(oField ==  null) app.alert("Error getting " + aNames[i] + " field!", 0, 1);
              else aValues[aValues.length] = oField.value;
              if(aValues.length != 0) {
              // sum the non-N/A vlaues in the array;
              for(i = 0; i < aValues.length; i++) {
              if(String(aValues[i]).toUpperCase() != "N/A") {
              sum += Number(aValues[i]); // sum the non-N/A values;
              count++; // count the non-N/a values;
              // compute average if count not zero;
              if(count != 0) event.value = sum / (count * 5);
