2 Replies Latest reply on Nov 13, 2013 7:24 AM by Americo Pinto
    exporting XML with xmlExportPreferences
    Americo Pinto
      Hi everyone,
      I have write a javacsript to export xml file from InDesign. For the pretty ptrint I use allowTansform and transformFilename with an xslt script to indent my exported files. But, I have find out an unexpexted behaviour of my script at the export time. My xml files aren't indented.
      If I do first an export applying my xslt script by the user interface, the result is well done. Then after i use my javascript which it do nothing, It works well now. I don't see where is my misunderstood ?
      i hope that I clearly makes me understand.
      see my script :
      function mySnippet()
          with(app.xmlExportPreferences)
              allowTransform = false;
              // Préférences d'exportation au format XML
              charactersReferences = true;
              copyOptimizedImages = true;
              exportFromSelected = true;
              xmlFileEncoding = XMLFileEncoding.UTF8;
              transformFilename= File ('../prettyPrintXML.xsl');
              // Activation des variables locales
              var xmlElement;
              var myDocument = app.activeDocument;
              var xmlRoot = myDocument.xmlElements[0];
              myTagElement = xmlRoot.evaluateXPathExpression('//doc');
              xmlElements = xmlRoot.evaluateXPathExpression('//doc//article//texte');
              myAuthorRootTag = xmlRoot.evaluateXPathExpression('//composant-signature');
              myAuthorTag = myAuthorRootTag[0];
              myAuth = myAuthorTag.xmlContent.contents;
              myAuth1 = myAuth.split(" ");
              myAuthorFirstName = myAuth1 [1];
              myAuthorLastName = myAuth1 [2];
              myAuthor = myAuthorFirstName + ' ' + myAuthorLastName;
              myIssueRootTag = xmlRoot.evaluateXPathExpression('//issuedate');
              myIssueTag = myIssueRootTag[0];
              myIssueDate = myIssueTag.xmlContent.contents;
              alert (myAuthorFirstName + ' ' + myAuthorLastName);
              alert (myIssueDate);
              for (docPos = 0; docPos < myTagElement.length; docPos++)
                  xmlElement = myTagElement[docPos];
                  myArticle = docPos;
                  myDocPos = xmlElements[docPos].xmlContent.insertionPoints[0].parentTextFrames[0];
                  myPageName = + myDocPos.parentPage.name;
                  // Génération du fichier ".cont.xml"
                  myCont = myWorkFolder + '/' + myExportNameFile + '_' + myPageName.threeDigit() + '_' + myArticle.threeDigit() + '.cont.xml';
                  myFileCont = new File (myCont);
                  xmlElement.exportFile(ExportFormat.xml, myFileCont, false);
                  //Génération du fichier ".sys.xml"
                  mySys = myWorkFolder + '/' + myExportNameFile + '_' + myPageName.threeDigit() + '_' + myArticle.threeDigit() + '.sys.xml'
                  myFileSys = new File (mySys);
                  var myXMLElement = myDocument.xmlElements.item(0).xmlElements.item(-2);
                  myXMLElement.exportFile(ExportFormat.xml, myFileSys, false);
                  //Génération du fichier ".meta.xml"
                  myMeta = myWorkFolder + '/' + myExportNameFile + '_' + myPageName.threeDigit() + '_'+ myArticle.threeDigit() + '.meta.xml';
                  myFileMeta = new File (myMeta);
                  var myXMLElement = myDocument.xmlElements.item(0).xmlElements.item(-1);
                  myXMLElement.exportFile(ExportFormat.xml, myFileMeta, false);
      thanks
      Américo
