1 Reply Latest reply on Nov 12, 2013 12:21 PM by sinious
    Pressure sensitivity
    Vladdie93
      Hello.
      I have a Monoprice tablet, and I want to use the pressure sensitivity in Flash. It works on Photoshop, and it seems to work fine on its own testing in the settings.
      I've been told there's some sort of icon that I can use for turning on and off pressure sensitivity, but I haven't found it anywhere. What should I do?
      Thanks for your time!
        • 1. Re: Pressure sensitivity
          sinious Most Valuable Participant
          If Flash detects you have a pressure sensitive capability via your driver you should see the standard "comma" looking icon appear in brush settings. If not then the icon doesn't appear. You might want to try some different drivers to see if an older/newer driver triggers the functionality.
