1. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
Kevin-Monahan Nov 12, 2013 4:44 PM (in response to BalukMagic)Hi BalukMagic,
Import them using the Media Browser. See if that works for you.
Kevin
2. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
BalukMagic Nov 12, 2013 4:53 PM (in response to Kevin-Monahan) -
3. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
Kevin-Monahan Nov 12, 2013 5:00 PM (in response to BalukMagic)Hi BalukMagic,
Which version of Premiere Pro are you using?
Kevin
4. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
BalukMagic Nov 12, 2013 5:06 PM (in response to Kevin-Monahan)CC 7.1.0 (141).
The latest.
Please note these raw files are from a new camera (the newly released firmware on the pocket camera was upgraded today, not to be confused with the other blackmagic camera which already had raw before)
5. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
petergaraway Nov 12, 2013 5:11 PM (in response to BalukMagic)Would you be willing to upload a small sample file that I could look at? You can PM me the link.
Also, please let us know what firmware version you have.
Thanks!
Peter Garaway
Adobe
Premiere Pro
6. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
BalukMagic Nov 12, 2013 5:37 PM (in response to petergaraway)I have sent a sample. The camera firmware is 1.5
7. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
DarthKcaj Nov 12, 2013 6:21 PM (in response to BalukMagic)I have had similar issues, keen to see the outcome with this.
8. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
symonty Nov 13, 2013 8:41 AM (in response to DarthKcaj)Same issue, both AE and PS work fine, but SG and Premiere pro 7.1 will not load the frame.
I have uploaded a sample DNG file to my server,
http://www.symonty.org/dng/test.dng
Submitted a bug report here: https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
Lets see what happens next.
******BUG******
Concise problem statement:
Premiere Pro will not open nor decode Black Magic DNG files from the BlackMagic Cinema Camera.
Steps to reproduce bug:
1. Import or drag the sequence of DNG files from the bmpcc into premere pro
2. They will be recognized as a sequence of DNG files
3. Error message appears.
Results:
Unable to Deocde , or File missing metadata error sequence is not usable.
Expected results:
Files should import into the bin for use in the edit.
Files are fully decoded and usable in After Effects and Photoshop so the files are compliant.
9. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
symonty Nov 13, 2013 2:42 AM (in response to petergaraway) -
10. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
Studio North Films Nov 13, 2013 4:45 AM (in response to BalukMagic)Same issue here, very dissapointed. please sort out asap
11. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
iconoclast6 Nov 13, 2013 9:42 PM (in response to Kevin-Monahan)Hi,
Currently no method to import Cinema DNG fies into Premiere Pro CC or CS6 works.
The files will import into Photoshop or AfterEffects.
Please expedite providing a fix, as well have just completed a transition to Premiere for editing.
12. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
Dave Merchant Nov 13, 2013 10:52 PM (in response to iconoclast6)Please keep this discussion in one thread - it's been answered over here
13. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
BalukMagic Nov 13, 2013 10:55 PM (in response to Dave Merchant)Thanks for your help, but I posted this the day before, so it would be helpful for the other poster to keep to one thread.
14. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
Dave Merchant Nov 14, 2013 12:39 AM (in response to BalukMagic)Appreciate that, but the other thread is the one with the official response, and we can't move it.
15. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
petergaraway Nov 14, 2013 8:42 AM (in response to Dave Merchant)To bring the answer over to this thread to close the loop.
Only Cinema DNG files from the Blackmagic Cinema Camera are currently supported in Premiere Pro CC and SpeedGrade CC.
AfterEffects and PhotoShop use a different importer than Premiere Pro and SpeedGrade. So if you make a request for one (Premiere Pro) by default it will count for SpeedGrade as well.
Peter Garaway
Adobe
Premiere Pro
16. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
BalukMagic Dec 18, 2013 3:32 PM (in response to petergaraway)Is there any update on this at all? We've had another CC update to Speedgrade, but it has not appeared to fix this issue. Is there a way to confirm when this will be fixed?
17. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
Fuzzy Barsik Jan 20, 2014 12:26 PM (in response to BalukMagic)In case you are not aware of, Ginger HDR is capable of importing almost any RAW files into PrPro, and with the Playback Resolution set to 1/2 PrPro can play them back in real time on a not quite powerful machine.
18. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
BalukMagic Jan 21, 2014 1:58 PM (in response to Fuzzy Barsik)I did not know that. this is a feature i need very badly in Premiere and Speedgrade. I don't like working in Resolve, and I've taught myself Speedgrade.
I hope Ginger HDR can fix that for me. Will test it
19. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
Fuzzy Barsik Jan 21, 2014 2:05 PM (in response to BalukMagic)Out of curiousity: have you tried converting BMPCC CinemaDNG into DNG via Adobe DNG Converter? My guess was if DNG Converter uncompresses BMPCC CinemaDNG files during conversion, and the resulting files are approximately 15% larger. But I'm on CS5.5 and can't test if PrPro CC can import them 'natively'.
20. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
BalukMagic Jan 21, 2014 2:11 PM (in response to Fuzzy Barsik)I have not tried that. Ginger HDR does indeed let me import the compressed CinemaDNG files into PrCC. Unfortunately, dynamic link to speedgrade and the media is offline. And it also will not show the footage in the source monitor.. Just when on a timeline,
21. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
Fuzzy Barsik Jan 21, 2014 2:24 PM (in response to BalukMagic)It does show footage in the Source Monitor, it doesn't send it into via double-click, hence you have to drag it and drop.
Regard to SpeedGrade, well, if I'm not mistaken, John is on CS5.5 as well...
22. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
BalukMagic Jan 21, 2014 3:19 PM (in response to Fuzzy Barsik)Sorry, who is John?
23. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
Fuzzy Barsik Jan 21, 2014 11:52 PM (in response to BalukMagic)John Hable, the Ginger HDR developer.
By the way, did you have time to test Adobe DNG Converter - I'm curious.
24. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
BalukMagic Apr 8, 2014 9:02 AM (in response to petergaraway)So there is a new update under way. Can anyone confirm if it is v7.2.2, the latest update that I received yesterday?
I still can't seem to open the raw files from my Pocket Camera.
25. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
SteveHoeg Apr 8, 2014 9:10 AM (in response to BalukMagic)7.2.2 is just a bug release that doesn't contain major new features. The next release of Premiere Pro that we revealed last week coming soon includes support for the BlackMagic Pocket Camera, as well as other CinemaDNG enhancements such as source settings (eg exposure controls), as well as supporting proper colour science for a wider range of DNG files from other recorders.
26. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
BalukMagic Apr 8, 2014 9:12 AM (in response to SteveHoeg)Thanks, I wish there was a more clear way to present that. The "What's New" tab in cloud stated new support for Camera Raw and included support for new cameras. Vague enough to be taken as the new update.
27. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
mattispositive Apr 11, 2014 11:43 AM (in response to SteveHoeg)Steve, is there any timeline on the next big release for Premiere Pro? Getting CinemaDNG support is going to be huge for a lot of us, including myself, as the current workflow of going through Resolve to PP to Resolve again is extremely time consuming. Also - will this bigger update include CinemaDNG support for the FS700/Odyssey7Q RAW files? Excited that Source Settings is going to be available!
28. Re: Black Magic Pocket Camera / Cinema DNG (compressed)
petergaraway Apr 15, 2014 11:21 AM (in response to mattispositive)Sorry can't provide a date to the next release.
In the next release we added support for Convergent Design Odyssey7Q. Here's an excerpt from our blog post about whats coming next:
"Premiere Pro’s rich support for workflows in 5K and beyond is further enhanced, with new native support for CanonRAW and Sony SStP media. Enhanced CinemaDNG support (including Blackmagic Pocket Cinema Camera, Convergent Design Odyssey7Q, and CinemaDNG source settings)."
Check out the rest of the features here:
https://blogs.adobe.com/premierepro/2014/04/thenextpremiereproccrelease.html
Best,
Peter Garaway
Adobe
Premiere Pro
