9 Replies Latest reply on Mar 17, 2016 9:08 AM by diegos93050643
      • 1. Re: Is there a way to detect the end of a video?
        elainecc Adobe Employee
        Hi, ae_komatsu-
        Yes, the YouTube JavaScript API gives you access to an event that will fire when your video finishes playing.
        https://developers.google.com/youtube/js_api_reference#Events
        Look at onStateChange.
        -Elaine
        • 2. Re: Is there a way to detect the end of a video?
          TonyEllisMedia Level 1
          Elaine,
          Does this process work for ipads?
          They have an example but it seems to be for flash.
          I am still learning and I guess that I am not comfortable on how and what syntax I need to be placing my script in the actions panel in Adobe Edge.
          I have also been having a problem of when I load youtube videos on a timeline and hit play on one and then go to my next video the old video is still playing in the background.
          (I know the sxyntax is not right)
          I want:
          onstartclipevent
          var = truckvideos
          truckvideos.playvideo1"mylocalipad/trucks/video1"
          if video1 statecomplete
          stopAllideoactions and audio
          gotoAndplay ("whateversymbol");
          var = dozervideos
          truckvideos.playvideo1"mylocalipad/dozer/video1"
          stopvideoactions and audio
          var = excavatorvideos
          excavatorvideos.playvideo1"mylocalipad/excavator/video1"
          var = loadervideos
          loadervideos.playvideo1"mylocalipad/trucks/video1"
          Does this make sense?
          -Tony
          • 3. Re: Is there a way to detect the end of a video?
            RavenDesign Level 1
            For youtube the code would be something like this:
            view-source:calkaweb.herobo.com/video.html
            for HTML5 videos for youtube replace &version=3 with &html5=1 in the youtube URL
            I have no idea how to impletent the youtube code into Edge tho other than an iframe but that wouldn't work I've tried :
            http://forums.adobe.com/thread/1285212
            You would need to place all of the youtube codes into edge in order for it to work but I duno how to do that and no1 answered the question in the thread I made about it.
            as for MP4/HTML5 video you can use
            var video = document.getElementsByTagName('video')[0];
                video
            .onended = function(e) {
            /*Do Something*/
            • 4. Re: Is there a way to detect the end of a video?
              bryann design Level 1
              I just saw this on stack overflow and it worked! I wanted to add tracking and a bigPlay button again when it ended so the user has a better experience.
              Detect when an HTML5 video finishes - Stack Overflow
              //actions for when video is done player (hide/show stuff, play animation, etc.)
                video.onended = function(e) {
                // Show an element
                sym.$("play_button").show();
              • 5. Re: Is there a way to detect the end of a video?
                joel_pau Level 5
                Yes but using Edge API: Adobe Edge Animate CC JavaScript API
                Code is:
                sym.$("my_video_element")[0].onended = function(e){ console.log(e, e.type, e.target) };
                or
                var video = sym.$("my_video_element")[0];
                video.onended = function(e){ console.log(e, e.type, e.target) };
                • 6. Re: Is there a way to detect the end of a video?
                  joel_pau Level 5
                  Simpler ideas:
                  1) Code.
                  sym.$("my_video_element").bind( "ended", function(e){ doSomething }) ;
                  2) Edge UI.
                  You can customize and get:videoEventEdgeUI.jpg
                  How shall we do it?
                  • First step: you select your video element and add a click event as shown below:
                  • Second step: you click on "Full code" to replace click by ended as shown below:
                  • Third step: clicking on the "Full Code" button again.
                  • 7. Re: Is there a way to detect the end of a video?
                    diegos93050643 Level 1
                    Hey @joel_pau, that looks good.
                    I'm trying to play a another video automatically after the first video ended. I know that your post is the solution but I'm not getting this to work
                    I am getting this but what does the "{ console.log(e, e.type, e.target) };" do?
                    and where shall I put the code you posted:
                    sym.$("my_video_element").bind( "ended", function(e){ PLAY THE OTHER VIDEO }) ;    ????
                    I would really appreciate an answer!
                    Thanks!
                    • 8. Re: Is there a way to detect the end of a video?
                      ddhayles Level 3
                      This should do the same as the code others have written, but you can give it a go.
                      Put this in your document.compositionReady and make sure both your videos are on the root timeline:
                      sym.$("video1")[0].addEventListener("ended", function(){
                           sym.$("video1").hide();
                           sym.$("video2")[0].play();
                        }, false);
                      • 9. Re: Is there a way to detect the end of a video?
                        Dear ddhayles,
                        thank you so much for this. It is like you said, I just didnt get it on the first attept... my fault. But finally I got this working.
                        Virtual Beers to the whole Community! You guys are awesome!
                        Diego
