1 Reply Latest reply on Nov 13, 2013 9:11 AM by Brian Havlin
    2 column form
      how do you create a 2 column A4 form ?
        • 1. Re: 2 column form
          Brian Havlin Adobe Employee
          Use the "Insert Item Beside" button, highlighted in the screenshot below, to create a second column of form items.
          Currently, aligning the form items to give your columns uniform width is a manual process.
          To specify the A4 output format, click the "Form Setup" button at the end of the toolbar in the Design view, then select A4 for the "PDF Paper Size" option.
