1 Reply Latest reply on Nov 13, 2013 2:17 PM by Steven.Madwin
    Sign a form without saving as a new file
    ksaokv
      It would be nice if someone could help with an Acrobat XI forms problem:
      If I add a signature (within a form field) I can't save the file with the same name. The procedure always suggests to "save as ..." with a specific file name.It is possible  to overwrite the given file name what I like to avoid. I only want to add changes to the existing file - sign and save.
        • 1. Re: Sign a form without saving as a new file
          Steven.Madwin Adobe Employee
          Hi ksaoka,
          When the Save As dialog pops up all you need to do is click the Save button and then you'll see this dialog:
          All you need to do is click the Yes button and you're done. If the Save operation is failing then you probably don't have write permissions to the save as location. It could be something else like your disk is full, but usually it's a permissions issue.
          Steve
