7 Replies Latest reply on Apr 26, 2017 5:55 AM by im_pacman
    shrink/grow mask
    1st air cav
      I have a older graphics program called Picture Publisher. I used this for years until I eventually moved over to PS. The grow / shrink mask tool in PP is easy to use but I cannot figure out how to do this in PS. Take the letter B in the upper left corner. I can use the mask tool on the B and shrink it, leaving me with the outline of the B. I can shrink or grow the mask by indicating how many pixols to shrink or grow. For the life of me I can't seem to do this in PS. Presently I do it in PP then open the graphic in PS wher I can then use it. Is there a way to accomplish this in PS?
        • 1. Re: shrink/grow mask
          MikeGondek Adobe Community Professional & MVP
          Good question. You would think between the options here you could do that, but you cannot.
          1. Command click on mask -  to make selection based upon mask.
          2. select >> modify >> Expand/contract
          3. fill with black/white
          • 2. Re: shrink/grow mask
            1st air cav Level 1
            is this option in PS CS5? I can't seem to find this refine mask. There is a refine edge but this does not open to the properties window.
            • 3. Re: shrink/grow mask
              1st air cav Level 1
              Thanx but i'm still in the dark. I'll keep trying. Mostly I keep hitting
              buttons till it starts to act right. I've never had any training using PP
              or PS. Pretty much just play with it until i hit the right button and yell
              eureka I got it. This was the first time I had used the forum for an
              answer. Thanx again.
              • 4. Re: shrink/grow mask
                Earth Oliver Level 3
                with a layer mask selected, you can also use Filter/Other/Min or Max to expand or contract a mask.
                • 5. Re: shrink/grow mask
                  1st air cav Level 1
                  Thanx, that answer was exactly what I have been looking for. That shrinking
                  and expanding of a mask was one of the things I had not been able to figure
                  out. I pretty much trained myself using Picture Publisher and it has been a
                  bit trying at times to accomplish the same in PS. Going from one software
                  to another without the understanding of the logic is, well it strains the
                  mind. I enjoy PS and it has so much more that can be done with it. I don't
                  really use PS for photos. I scan ink drawing into it and then I use the
                  computer to color and manipulate the drawings. I don't do it for a job. I
                  pretty much use it to annoy my friends and as a hobby. Thanks again. The
                  expanding and contracting mask had been driving me nuts for some time. As i
                  said this was the first time I have use the forum and I will include it
                  into my resource box rather than banging my head against the wall. [image:
                  Inline image 1]
                  • 6. Re: shrink/grow mask
                    Doug.S Level 3
                    Before mask is created, you can use the menu/selection/  to add/increase or reduce the selection, (by your choice of the number of pixels) then convert that to a mask, or when you choose 'add an adjustment layer', the selection will automatically create the mask on the new adjustment layer.
                    • 7. Re: shrink/grow mask
                      im_pacman
                      it's awesome! thank you!
