1 Reply Latest reply on Nov 13, 2013 3:27 PM by bregent
    Using the same field on a form for multiple menu/drop down list
    c.a.logan Level 1
      I have a form that tracks people that attend orientations.  It is possible for an Attendee to attend the same orientation up to three times.
      In using the Update record wizard, I have two recordsets, rsAttendees and rsOrientation from two separate tables.
      I want to be able to use the rsOrientation to create a drop down list, but I want to use that same recordset field as the source for the dropdown 3 times on the same record.
      There are 3 fields on the Attendee form:
      Orientation1, Orientation2, and Orientation3.
      Using the wizard, I set each up as a Menu, then select the rsOrientation, Orientation.Date as the source for all 3.
      The problem is that only the Orientation1 field is populated.  Orientation2 and Orientation3 dropdowns are blank.
      Orientation1: __________________<-----------Using Wizard, pull Menu list from Orientation.Date This one works fine
      Orientation2: __________________<-----------Using Wizard, pull Menu list from Orientation.Date This one is blank
      Orientation3: __________________<-----------Using Wizard, pull Menu list from Orientation.Date This one is blank
      Do I need to reset the rs somehow?
