1. Re: Complex Boolean Expressions in FrameMaker
Russ Ward Nov 14, 2013 4:40 AM (in response to AMCGracer)Hi AMCGracer,
I would never dream of trying to use native conditional text for this... I would use structured FM, attribute values, and the AXCM plugin. Of course I would, though, since I wrote the plugin (disclaimer). Anyway, you are bumping in to the classic limitations of unstructured content... there just isn't enough intelligent markup to do the type thing you want. BTW, AXCM is free.
http://www.weststreetconsulting.com/WSC_AXCM.htm
Russ
2. Re: Complex Boolean Expressions in FrameMaker
AMCGracer Nov 14, 2013 6:08 AM (in response to Russ Ward)Hi Russ,
Thanks for the answer, though it's what I was afraid of.
So a couple of follow up questions.... is it possible to migrate a large complex document set to structured FrameMaker? Will it still support my Robohelp integration for WebHelp output?
How would you estimate the effort involved?
Thank you again,
--Amy
3. Re: Complex Boolean Expressions in FrameMaker
Russ Ward Nov 14, 2013 7:44 AM (in response to AMCGracer)Hi Amy,
It's no simple matter, so I don't mean to casually suggest that you'll be able to do it in an afternoon. It is a long term process to understand the structured mindset and build the architecture to support it. I couldn't possible estimate an effort from here because there are so many variables involved. Typically, though, you are looking at months to pull off any kind of substantial transition.
That said, a structured document set is the only way you'll be able to realize your goals. Unstructured content, whether in FrameMaker, Word, or wherever, lacks the metadata to engage the computer for the type of automation that you want. For the computer to do work for you, you'll need to make your content look like data to the computer. This doesn't have to be structured Frame, as there are many avenues to this destination. It is a convenient option, though, for those already using FrameMaker and are satisfied with the authoring platform and publishing options.
4. Re: Complex Boolean Expressions in FrameMaker
Russ Ward Nov 14, 2013 7:47 AM (in response to Russ Ward)Here's the rest of that post... accidentally submitted too early (dang that Ctrl+S habit!)
So in summary, it is possible and I'm sure that your RoboHelp usage will remain intact. But it's not trivial. Despite the effort, though, the rewards are enormous. Unstructured Frame is technology that is decades old, which is why nothing new and really cool happens with it. Everything on the cutting edge involves structured content, because everything on the cutting edge involves the computer doing more and more work.
Russ
5. Re: Complex Boolean Expressions in FrameMaker
mattrsullivan Nov 14, 2013 9:18 AM (in response to AMCGracer)@Amy,
Yes, you can retain your Fm > Rh workflow. When you switch to structure, though, retain the paragraph format name, even if you use the EDD formatting rules.
You'll still need the paragraph format name as an identifier for the Rh mapping process.
A bonus: because your mappings already exist, you should find much of the process will already be complete.
-Matt
