How to create web service for interactive forms using Adobe forms in .NET
Prasanthkrish Nov 13, 2013 8:35 PMHello Sir,
I am trying to implement interactive forms using Adobe forms in .NET
Where can I find the below highlighted web service and it methods.
???using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.ServiceModel;
using System.IO;
using RenderPDFForm.ServiceReference1;
namespace RenderPDFForm
class Program
static void Main(string[] args)
try
//Create a FormsServiceClient object
FormsServiceClient formsClient = new FormsServiceClient();
formsClient.Endpoint.Address = new System.ServiceModel.EndpointAddress("http://hiro-xp:8080/soap/services/FormsService?blob=mtom");
//Enable BASIC HTTP authentication
BasicHttpBinding b = (BasicHttpBinding)formsClient.Endpoint.Binding;
b.MessageEncoding = WSMessageEncoding.Mtom;
formsClient.ClientCredentials.UserName.UserName = "administrator";
formsClient.ClientCredentials.UserName.Password = "password";
b.Security.Transport.ClientCredentialType = HttpClientCredentialType.Basic;
b.Security.Mode = BasicHttpSecurityMode.TransportCredentialOnly;
b.MaxReceivedMessageSize = 2000000;
b.MaxBufferSize = 2000000;
b.ReaderQuotas.MaxArrayLength = 2000000;
//Reference the XDP document to render
string inputFileName = "C:\\Adobe\Loan.xdp";
FileStream fs = new FileStream(inputFileName, FileMode.Open);
//Get the length of the file stream
int len = (int)fs.Length;
byte[] ByteArray = new byte[len];
//Populate the byte array with the contents of the FileStream object
fs.Read(ByteArray, 0, len);
BLOB inDoc = new BLOB();
inDoc.MTOM = ByteArray;
//Set run-time options
PDFFormRenderSpec renderSpec = new PDFFormRenderSpec();
renderSpec.generateServerAppearance = true;
//Set out parameter values
long pageCount = 1;
String localeValue = "en_US";
FormsResult result = new FormsResult();
//Render an interactive PDF form by ivoking the renderPDFForm2 method
formsClient.renderPDFForm2(
inDoc,
null,
renderSpec,
null,
null,
out pageCount,
out localeValue,
out result);
//Populate a byte array with BLOB data
RenderPDFForm.ServiceReference1.BLOB outDoc = result.outputContent;
byte[] outByteArray = outDoc.MTOM;
//Save the interactive form as a PDF file
string fileName = "C:\\Adobe\Loan.pdf";
FileStream fs2 = new FileStream(fileName, FileMode.OpenOrCreate);
//Create a BinaryWriter object
BinaryWriter w = new BinaryWriter(fs2);
w.Write(outByteArray);
w.Close();
fs2.Close();
catch (Exception ee)
Console.WriteLine(ee.Message);
Best Regards,
prasanth.k
