0 Replies Latest reply on Dec 29, 2007 1:40 PM by Cf_Bob
    Help with Step Debugger in CF 8
      Hi all- I'm trying to set up the CF 8 step debugger via the CFEclipse plugin. I have RDS setup up properly, as I can verify via the Eclipse Preferences that the connection and the debugger are working (via the "test XXX" buttons). I can even set some break points and trace through a file using the debugger.
      Unfortunately I can never seem to inspect any variables properly. The variables window is just always empty. I've tried several different scopes (application, server, etc.), and in CF Admin I have made sure the Variables debugging is enabled (not sure if this applies to the debugger or the dumps on each page). I also tried with and without the CFML exception break option enabled.
      Any ideas on what I can do to actually inspect some variables?
