13 Replies Latest reply on Oct 18, 2017 2:28 PM by jeromiec83223024 Branched to a new discussion.
    Flash 11.9.900.152 crashes when Protected Mode Enabled
    gh0stmaster
      The latest version of Aurora, v27, is crashing with the latest flash, 11.9.900.152, when Protected Mode is Enabled
      Im in windows 8.1 x64
      Here are a bunch of crash reports of this. I can generate more if needed
      2d2038df-7854-4e79-b695-d2f5a7b80a5c
      ee2001f6-390f-4979-8500-17bc6f4c2fbc
      79303d95-9bad-4009-8d8a-9c360ba1ee06
      0d52b914-7412-4358-8e7d-61e5b1207e56
      82485525-51ee-4faf-bc8d-9061769b852c
      f71da362-c3fb-4922-a792-52a2a275904e
        • 1. Re: Flash 11.9.900.152 crashes when Protected Mode Enabled
          chris.campbell Adobe Employee
          Thank you for the heads up.  I've forwarded this to our QE team for investigation.  I'd also recommend opening a new bug report over at https://bugbase.adobe.com if you have a chance.
          • 3. Re: Flash 11.9.900.152 crashes when Protected Mode Enabled
            jeromiec83223024 Adobe Employee
            I can't really do anything with that data -- it's just a random unique ID assigned to the crash dump on your system.  The reports need to be submitted to Mozilla, and I need the links to the reports to tell you what's up.
            In about:crashes, click on each of those links.  Firefox will submit them (if you get the throttling message, just submit them again), and the crash ID will change to begin with "bp-xxxxxx".
            On each of the bp-xxxxx links, right click each of them and choose "copy link".  Post the links here, and I'll take a look.
            While you're at it, if you could post the contents of about:support and about:plugins, that would also be very helpful.
            Thanks!
            • 4. Re: Flash 11.9.900.152 crashes when Protected Mode Enabled
              gh0stmaster Level 1
              So Ive tried it in Aurora 27 and Firefox 26, both crash with protected mode. Protected mode being disabled fixes it (temporarily, although I dont want to leave it like this). Firefox/Aurora safe mode did NOT fix it. Also, if I browse youtube without installing the flash plugin and just ignoring the prompt for it, it works fine
              Ive also tried it with a brand new firefox profile, and with all extensions disabled
              Here, try this
              bp-ef13c380-116a-438a-9b40-be0522131114
              bp-6cd46090-f51a-4483-9cb9-d2ee72131114
              bp-43f44b99-d101-49f3-a014-3db3e2131114
              bp-60790199-243f-4fe5-9d36-1bf1e2131114
              bp-b0931046-cdca-466b-9f8c-9f3962131114
              bp-6cd229b4-ac3a-4d5e-b54f-cae222131114
              bp-4008b1bb-c93b-43a3-bcc9-8237f2131114
              bp-88281ee0-de82-4509-b2b1-b9e6c2131114
              https://crash-stats.mozilla.com/report/index/6cd229b4-ac3a-4d5e-b54f-cae222131114
              https://crash-stats.mozilla.com/report/index/b0931046-cdca-466b-9f8c-9f3962131114
              https://crash-stats.mozilla.com/report/index/60790199-243f-4fe5-9d36-1bf1e2131114
              https://crash-stats.mozilla.com/report/index/43f44b99-d101-49f3-a014-3db3e2131114
              https://crash-stats.mozilla.com/report/index/6cd46090-f51a-4483-9cb9-d2ee72131114
              https://crash-stats.mozilla.com/report/index/ef13c380-116a-438a-9b40-be0522131114
                       Application Basics
              Name Firefox
              Version 27.0a2
              Update History
              User Agent Mozilla/5.0 (Windows NT 6.3; WOW64; rv:27.0) Gecko/20100101 Firefox/27.0
              Profile Folder
              Enabled Plugins about:plugins
              Build Configuration about:buildconfig
              Memory Use about:memory
              Crash Reports for the Last 3 Days
              bp-ef13c380-116a-438a-9b40-be052213111421 minutes ago
              bp-6cd46090-f51a-4483-9cb9-d2ee7213111421 minutes ago
              bp-43f44b99-d101-49f3-a014-3db3e213111422 minutes ago
              bp-60790199-243f-4fe5-9d36-1bf1e213111422 minutes ago
              bp-b0931046-cdca-466b-9f8c-9f396213111422 minutes ago
              bp-6cd229b4-ac3a-4d5e-b54f-cae22213111422 minutes ago
              bp-4008b1bb-c93b-43a3-bcc9-8237f213111437 minutes ago
              bp-88281ee0-de82-4509-b2b1-b9e6c213111440 minutes ago
              bp-2a719e4e-428b-4729-b6b6-6565d21311143 hours ago
              All Crash Reports (including 27 pending crashes in the given time range)
              This application has not been configured to display crash reports.
              Extensions
              Adblock Plus2.4true{d10d0bf8-f5b5-c8b4-a8b2-2b9879e08c5d}
              Adblock Plus Pop-up Addon0.9.1trueadblockpopups@jessehakanen.net
              Apollo Bookmark/Tab/History Sync add-on0.8.10trueffsync@apollobrowser.com
              Clear Cache Button0.9ftrue{563e4790-7e70-11da-a72b-0800200c9a66}
              DownThemAll!2.0.16true{DDC359D1-844A-42a7-9AA1-88A850A938A8}
              Enhanced Steam4.2truejid0-SmvlvxGpvCyG252KbVMqIKR79Uc@jetpack
              FireGestures1.7.14truefiregestures@xuldev.org
              Flagfox4.2.14true{1018e4d6-728f-4b20-ad56-37578a4de76b}
              FlashGot1.5.5.94true{19503e42-ca3c-4c27-b1e2-9cdb2170ee34}
              InlineDisposition1.0.2.4true{123647d5-da43-4344-bfe2-fc093bdf8f5e}
              MyPermissions Cleaner0.8.0true{6140bbfd-aa20-11e1-aba7-109add603214}
              NewScrollbars (aka NoiaScrollbars)1.2.1trueNoiaScrollbars@ArisT2_Noia4dev
              OpenDownload²3.4.3true{210249CE-F888-11DD-B868-4CB456D89593}
              Readability2.4true{6005d9b1-d115-485a-a92a-3f6453ca3fe2}
              Scrollbar Search Highlighter1.57truescrollbar.search.highlighter@rob.iverson.com
              Search By Image (by Google)1.1.2true{ce7e73df-6a44-4028-8079-5927a588c948}
              Session Manager0.8.0.8true{1280606b-2510-4fe0-97ef-9b5a22eafe30}
              Speed Dial0.9.6.16true{64161300-e22b-11db-8314-0800200c9a66}
              Status-4-Evar2013.10.31.22truestatus4evar@caligonstudios.com
              Surfon1.2.6truejid1-1fuWLZWF6WAUng@jetpack
              Suspend background tabs1.0.1truesuspendbackgroundtabs@adblockplus.org
              Tab Mix Plus0.4.1.2.02true{dc572301-7619-498c-a57d-39143191b318}
              Adobe Acrobat - Create PDF2.0falseweb2pdfextension@web2pdf.adobedotcom
              BYTubeD - Bulk YouTube video Downloader1.1.1falsebytubed@cs213.cse.iitk.ac.in
              Download Statusbar0.9.10false{D4DD63FA-01E4-46a7-B6B1-EDAB7D6AD389}
              Download Statusbar Fixed0.9.10false{4204c864-50bf-467a-95b3-0912b7f15869}
              Extended Statusbar1.5.8false{daf44bf7-a45e-4450-979c-91cf07434c3d}
              Fast Dial4.11falsefastdial@telega.phpnet.us
              FoxVox1.7.9.1falsefoxvox@wordit.com
              FxIF0.4.7.1false{11483926-db67-4190-91b1-ef20fcec5f33}
              Greasemonkey1.12false{e4a8a97b-f2ed-450b-b12d-ee082ba24781}
              Save Images0.9.5falseLDSI_plashcor@gmail.com
              The Grim Tab Reaper0.2falsejid1-VOwFjnJ0krddcw@jetpack
              Theme Font & Size Changer7.2false{f69e22c7-bc50-414a-9269-0f5c344cd94c}
              Toggle Word Wrap1.9false{cafe3945-058e-47e3-87f8-75bc120b9638}
              User Agent Switcher0.7.3false{e968fc70-8f95-4ab9-9e79-304de2a71ee1}
              Important Modified Preferences
              accessibility.typeaheadfind.flashBar0
              browser.cache.disk.capacity358400
              browser.cache.disk.smart_size.first_runfalse
              browser.cache.disk.smart_size.use_old_maxfalse
              browser.cache.disk.smart_size_cached_value358400
              browser.places.smartBookmarksVersion4
              browser.sessionstore.upgradeBackup.latestBuildID20131114004000
              browser.startup.homepagehttp://www.netvibes.com/
              browser.startup.homepage_override.buildID20131114004000
              browser.startup.homepage_override.mstone27.0a2
              browser.tabs.warnOnClosefalse
              dom.max_script_run_time0
              dom.mozApps.usedtrue
              dom.w3c_touch_events.exposefalse
              extensions.lastAppVersion27.0a2
              font.internaluseonly.changedfalse
              gfx.direct3d.last_used_feature_level_idx0
              gfx.direct3d.prefer_10_1true
              media.windows-media-foundation.enabledfalse
              network.cookie.prefsMigratedtrue
              network.http.max-persistent-connections-per-server4
              places.database.lastMaintenance1384386283
              places.history.expiration.transient_current_max_pages104858
              plugin.disable_full_page_plugin_for_typesapplication/pdf,audio/x-mpeg
              plugin.importedStatetrue
              print.printer_Canon_MX300_series_Printer.print_bgcolorfalse
              print.printer_Canon_MX300_series_Printer.print_bgimagesfalse
              print.printer_Canon_MX300_series_Printer.print_colorspace
              print.printer_Canon_MX300_series_Printer.print_command
              print.printer_Canon_MX300_series_Printer.print_downloadfontsfalse
              print.printer_Canon_MX300_series_Printer.print_duplex0
              print.printer_Canon_MX300_series_Printer.print_edge_bottom0
              print.printer_Canon_MX300_series_Printer.print_edge_left0
              print.printer_Canon_MX300_series_Printer.print_edge_right0
              print.printer_Canon_MX300_series_Printer.print_edge_top0
              print.printer_Canon_MX300_series_Printer.print_evenpagestrue
              print.printer_Canon_MX300_series_Printer.print_footercenter
              print.printer_Canon_MX300_series_Printer.print_footerleft&PT
              print.printer_Canon_MX300_series_Printer.print_footerright&D
              print.printer_Canon_MX300_series_Printer.print_headercenter
              print.printer_Canon_MX300_series_Printer.print_headerleft&T
              print.printer_Canon_MX300_series_Printer.print_headerright&U
              print.printer_Canon_MX300_series_Printer.print_in_colortrue
              print.printer_Canon_MX300_series_Printer.print_margin_bottom0.5
              print.printer_Canon_MX300_series_Printer.print_margin_left0.5
              print.printer_Canon_MX300_series_Printer.print_margin_right0.5
              print.printer_Canon_MX300_series_Printer.print_margin_top0.5
              print.printer_Canon_MX300_series_Printer.print_oddpagestrue
              print.printer_Canon_MX300_series_Printer.print_orientation0
              print.printer_Canon_MX300_series_Printer.print_page_delay50
              print.printer_Canon_MX300_series_Printer.print_paper_data1
              print.printer_Canon_MX300_series_Printer.print_paper_height 11.00
              print.printer_Canon_MX300_series_Printer.print_paper_name
              print.printer_Canon_MX300_series_Printer.print_paper_size_type0
              print.printer_Canon_MX300_series_Printer.print_paper_size_unit0
              print.printer_Canon_MX300_series_Printer.print_paper_width  8.50
              print.printer_Canon_MX300_series_Printer.print_plex_name
              print.printer_Canon_MX300_series_Printer.print_resolution0
              print.printer_Canon_MX300_series_Printer.print_resolution_name
              print.printer_Canon_MX300_series_Printer.print_reversedfalse
              print.printer_Canon_MX300_series_Printer.print_scaling  1.00
              print.printer_Canon_MX300_series_Printer.print_shrink_to_fittrue
              print.printer_Canon_MX300_series_Printer.print_to_filefalse
              print.printer_Canon_MX300_series_Printer.print_unwriteable_margin_bottom0
              print.printer_Canon_MX300_series_Printer.print_unwriteable_margin_left0
              print.printer_Canon_MX300_series_Printer.print_unwriteable_margin_right0
              print.printer_Canon_MX300_series_Printer.print_unwriteable_margin_top0
              privacy.donottrackheader.enabledtrue
              privacy.sanitize.migrateFx3Prefstrue
              storage.vacuum.last.index1
              storage.vacuum.last.places.sqlite1382135610
              user.js Preferences
              Your profile folder contains a user.js file, which includes preferences that were not created by Aurora.
              Graphics
              Adapter DescriptionAMD Radeon HD 6900 Series
              Adapter Driversaticfx64 aticfx64 aticfx64 aticfx32 aticfx32 aticfx32 atiumd64 atidxx64 atidxx64 atiumdag atidxx32 atidxx32 atiumdva atiumd6a atitmm64
              Adapter RAM2048
              Device ID0x671d
              Direct2D Enabledtrue
              DirectWrite Enabledtrue (6.3.9600.16384)
              Driver Date9-26-2013
              Driver Version13.200.16.0
              GPU #2 Activefalse
              GPU Accelerated Windows1/1 Direct3D 10
              Vendor ID0x1002
              WebGL RendererGoogle Inc. -- ANGLE (AMD Radeon HD 6900 Series Direct3D9Ex vs_3_0 ps_3_0)
              windowLayerManagerRemotefalse
              AzureCanvasBackenddirect2d
              AzureContentBackenddirect2d
              AzureFallbackCanvasBackendcairo
              AzureSkiaAccelerated0
              JavaScript
              Incremental GC true
              Accessibility
              Activated false
              Prevent Accessibility 0
              Library Versions
              Expected minimum versionVersion in use
              NSPR4.10.24.10.2
              NSS3.15.3 Basic ECC3.15.3 Basic ECC
              NSSSMIME3.15.3 Basic ECC3.15.3 Basic ECC
              NSSSSL3.15.3 Basic ECC3.15.3 Basic ECC
              NSSUTIL3.15.33.15.3
              Installed plugins
              Find updates for installed plugins at mozilla.com/plugincheck
              Shockwave Flash
              File: NPSWF32_11_9_900_152.dll
              Path: C:\WINDOWS\SysWOW64\Macromed\Flash\NPSWF32_11_9_900_152.dll
              Version: 11.9.900.152
              State: Enabled
              Shockwave Flash 11.9 r900
              application/x-shockwave-flashAdobe Flash movieswf
              application/futuresplashFutureSplash moviespl
              VLC Web Plugin
              File: npvlc.dll
              Path: C:\Program Files (x86)\VideoLAN\VLC\npvlc.dll
              Version: 2.1.0.0
              State: Enabled
              VLC media player Web Plugin 2.1.0
              audio/mpegMPEG audiomp2,mp3,mpga,mpega
              audio/x-mpegMPEG audiomp2,mp3,mpga,mpega
              video/mpegMPEG videompg,mpeg,mpe
              video/x-mpegMPEG videompg,mpeg,mpe
              video/mpeg-systemMPEG videompg,mpeg,mpe,vob
              video/x-mpeg-systemMPEG videompg,mpeg,mpe,vob
              audio/mp4MPEG-4 audioaac,mp4,mpg4
              audio/x-m4aMPEG-4 audiom4a
              video/mp4MPEG-4 videomp4,mpg4
              application/mpeg4-iodMPEG-4 videomp4,mpg4
              application/mpeg4-muxcodetableMPEG-4 videomp4,mpg4
              video/x-m4vMPEG-4 videom4v
              video/x-msvideoAVI videoavi
              application/oggOgg streamogg
              video/oggOgg videoogv
              application/x-oggOgg streamogg
              application/x-vlc-pluginVLC plug-in
              video/x-ms-asf-pluginWindows Media Videoasf,asx
              video/x-ms-asfWindows Media Videoasf,asx
              application/x-mplayer2Windows Media
              video/x-ms-wmvWindows Mediawmv
              video/x-ms-wvxWindows Media Videowvx
              audio/x-ms-wmaWindows Media Audiowma
              application/x-google-vlc-pluginGoogle VLC plug-in
              audio/wavWAV audiowav
              audio/x-wavWAV audiowav
              audio/3gpp3GPP audio3gp,3gpp
              video/3gpp3GPP video3gp,3gpp
              audio/3gpp23GPP2 audio3g2,3gpp2
              video/3gpp23GPP2 video3g2,3gpp2
              video/divxDivX videodivx
              video/flvFLV videoflv
              video/x-flvFLV videoflv
              application/x-matroskaMatroska videomkv
              video/x-matroskaMatroska videomkv
              audio/x-matroskaMatroska audiomka
              application/xspf+xmlPlaylist xspfxspf
              audio/x-mpegurlMPEG audiom3u
              video/webmWebM videowebm
              audio/webmWebM audiowebm
              application/vnd.rn-realmediaReal Media Filerm
              audio/x-realaudioReal Media Audiora
              audio/amrAMR audioamr
              audio/x-flacFLAC audioflac
              Google Talk Plugin Video Accelerator
              File: npgtpo3dautoplugin.dll
              Path: C:\Users\j\AppData\Roaming\Mozilla\plugins\npgtpo3dautoplugin.dll
              Version: 0.1.44.29
              State: Enabled
              Google Talk Plugin Video Accelerator version:0.1.44.29
              application/vnd.gtpo3d.auto
              Google Talk Plugin Video Renderer
              File: npo1d.dll
              Path: C:\Users\j\AppData\Roaming\Mozilla\plugins\npo1d.dll
              Version: 4.9.1.16010
              State: Enabled
              Version 4.9.1.16010
              application/o1dGoogle Talk Plugin Video Renderero1d
              Google Talk Plugin
              File: npgoogletalk.dll
              Path: C:\Users\j\AppData\Roaming\Mozilla\plugins\npgoogletalk.dll
              State: Enabled
              Version 4.9.1.16010
              application/googletalkGoogle voice and video chatgoogletalk
              Microsoft Office 2013
              File: npMeetingJoinPluginOC.dll
              Path: C:\Program Files (x86)\Mozilla Firefox\plugins\npMeetingJoinPluginOC.dll
              Version: 15.0.4545.1000
              State: Enabled
              The plugin allows you to have a better experience with Microsoft Lync
              application/vnd.microsoft.communicator.ocsmeetingLync Plug-in for Firefox
              Google Update
              File: npGoogleUpdate3.dll,npGoogleUpdate3.dll
              Path: C:\Users\j\AppData\Local\Google\Update\1.3.21.165\npGoogleUpdate3.dll,C:\Program Files (x86)\Google\Update\1.3.21.165\npGoogleUpdate3.dll
              Version: 1.3.21.165
              State: Enabled
              Google Update
              application/x-vnd.google.update3webcontrol.3
              application/x-vnd.google.oneclickctrl.9
              Java(TM) Platform SE 7 U45
              File: npjp2.dll
              Path: C:\Program Files (x86)\Java\jre7\bin\plugin2\npjp2.dll
              Version: 10.45.2.18
              State: Enabled
              Next Generation Java Plug-in 10.45.2 for Mozilla browsers
              application/x-java-appletJava Applet
              application/x-java-beanJavaBeans
              application/x-java-vm
              application/x-java-applet;version=1.1.1
              application/x-java-bean;version=1.1.1
              application/x-java-applet;version=1.2
              application/x-java-bean;version=1.2
              application/x-java-applet;version=1.1.3
              application/x-java-bean;version=1.1.3
              application/x-java-applet;version=1.1.2
              application/x-java-bean;version=1.1.2
              application/x-java-applet;version=1.3
              application/x-java-bean;version=1.3
              application/x-java-applet;version=1.2.2
              application/x-java-bean;version=1.2.2
              application/x-java-applet;version=1.2.1
              application/x-java-bean;version=1.2.1
              application/x-java-applet;version=1.3.1
              application/x-java-bean;version=1.3.1
              application/x-java-applet;version=1.4
              application/x-java-bean;version=1.4
              application/x-java-applet;version=1.4.1
              application/x-java-bean;version=1.4.1
              application/x-java-applet;version=1.4.2
              application/x-java-bean;version=1.4.2
              application/x-java-applet;version=1.5
              application/x-java-bean;version=1.5
              application/x-java-applet;version=1.6
              application/x-java-bean;version=1.6
              application/x-java-applet;version=1.7
              application/x-java-bean;version=1.7
              application/x-java-applet;jpi-version=1.7.0_45
              application/x-java-bean;jpi-version=1.7.0_45
              application/x-java-vm-npruntime
              application/x-java-applet;deploy=10.45.2
              application/x-java-applet;javafx=2.2.45
              Java Deployment Toolkit 7.0.450.18
              File: npdeployJava1.dll
              Path: C:\Program Files (x86)\Java\jre7\bin\dtplugin\npdeployJava1.dll
              Version: 10.45.2.18
              State: Enabled (STATE_VULNERABLE_NO_UPDATE)
              NPRuntime Script Plug-in Library for Java(TM) Deploy
              application/java-deployment-toolkit
              iTunes Application Detector
              File: npitunes.dll
              Path: C:\Program Files (x86)\iTunes\Mozilla Plugins\npitunes.dll
              Version: 1.0.1.1
              State: Enabled
              iTunes Detector Plug-in
              application/itunes-pluginThis plug-in detects the presence of iTunes when opening iTunes Store URLs in a web page with Firefox.
              Adobe Acrobat
              File: nppdf32.dll,nppdf32.dll
              Path: C:\Program Files (x86)\Adobe\Reader 11.0\Reader\browser\nppdf32.dll,C:\Program Files (x86)\Adobe\Reader 11.0\Reader\AIR\nppdf32.dll
              Version: 11.0.5.3
              State: Enabled
              Adobe PDF Plug-In For Firefox and Netscape 11.0.05
              application/pdfAcrobat Portable Document Formatpdf
              application/vnd.adobe.pdfxmlAdobe PDF in XML Formatpdfxml
              application/vnd.adobe.x-marsAdobe PDF in XML Formatmars
              application/vnd.fdfAcrobat Forms Data Formatfdf
              application/vnd.adobe.xfdfXML Version of Acrobat Forms Data Formatxfdf
              application/vnd.adobe.xdp+xml Acrobat XML Data Packagexdp
              application/vnd.adobe.xfd+xmlAdobe FormFlow99 Data Filexfd
              Silverlight Plug-In
              File: npctrl.dll
              Path: C:\Program Files (x86)\Microsoft Silverlight\5.1.20913.0\npctrl.dll
              Version: 5.1.20913.0
              State: Enabled
              5.1.20913.0
              application/x-silverlightnpctrlscr
              application/x-silverlight-2
              Unity Player
              File: npUnity3D32.dll
              Path: C:\Users\j\AppData\LocalLow\Unity\WebPlayer\loader\npUnity3D32.dll
              Version: 4.2.0.11237
              State: Enabled
              Unity Player 4.2.0f4
              application/vnd.unityUnity Player datafileunity3d
              Nitro PDF plugin for Firefox and Chrome
              File: npnitromozilla.dll
              Path: C:\Program Files (x86)\Nitro Pro 8\npnitromozilla.dll
              Version: 8.5.2.10
              State: Enabled
              Adobe Acrobat
              File: nppdf32.dll
              Path: C:\Program Files (x86)\Adobe\Acrobat 11.0\Acrobat\Air\nppdf32.dll
              Version: 11.0.1.36
              State: Enabled
              Adobe PDF Plug-In For Firefox and Netscape 11.0.01
              File: NPSPWRAP.DLL
              Path: C:\PROGRA~2\MICROS~2\Office15\NPSPWRAP.DLL
              Version: 15.0.4420.1017
              State: Enabled
              The plugin allows you to have a better experience with Microsoft SharePoint
              application/x-sharepointSharePoint Plug-in for Firefox
              application/x-sharepoint-uc
              AdobeAAMDetect
              File: npAdobeAAMDetect32.dll
              Path: C:\Program Files (x86)\Common Files\Adobe\OOBE\PDApp\CCM\Utilities\npAdobeAAMDetect32.dll
              Version: 1.0.0.0
              State: Enabled
              A plugin to detect whether the Adobe Application Manager is installed on this machine.
              application/x-adobeaamdetectAdobeAAMDetect
              • 5. Re: Flash 11.9.900.152 crashes when Protected Mode Enabled
                Perfect, thanks.
                It looks like you're running into two different issues:
                This one is is a generic signature that occurs whenever Firefox kills Flash Player:
                https://crash-stats.mozilla.com/report/list?product=Firefox&signature=F1398665248_________ ____________________
                This one is not a crash that I'm familiar with:
                https://crash-stats.mozilla.com/report/list?product=Firefox&signature=F2102588022_________ __________________________________________________________________________________________ ___
                The interesting thing about this crash is that it's occuring in very low volumes.  I need to do some additional analysis, but my initial assessment is that it's specific to a unique combination of plugins or something.  If it was affecting the general Firefox population, we'd see much much higher volumes.
                I'm curious to know if this crash occurs with other Add-ons disabled.  You can go to Help > Restart with Add-ons Disabled to test that.
                • 6. Re: Flash 11.9.900.152 crashes when Protected Mode Enabled
                  gh0stmaster Level 1
                  I've tried it in firefox safe mode, in normal mode with all addons disabled, and on a fresh install with no addons installed
                  All test cases have been crashing
                  • 7. Re: Flash 11.9.900.152 crashes when Protected Mode Enabled
                    Can you tell me how to reproduce the crash?
                    • 8. Re: Flash 11.9.900.152 crashes when Protected Mode Enabled
                      gh0stmaster Level 1
                      All I do is use the latest version of aurora/firefox with the latest version of flash player, and keep protected mode on, and it crashes every time for me
                      I cant watch any videos at all unless I disable protected mode
                      • 9. Re: Flash 11.9.900.152 crashes when Protected Mode Enabled
                        I tried this on my Surface Pro 2 running Win8.1, Aurora 27.0a2 and Flash Player 11.9.900.117 and 12.0.0.3 and I'm not able to reproduce this issue.  I tried watching a few different youtube videos.
                        I'm wondering if this is related to video hardware acceleration -- this device has an Intel graphics chipset, but you have AMD hardware.  I'll try and track down a Win 8.1 device with similar graphics hardware tomorrow to see if I can reproduce there.
                        • 10. Re: Flash 11.9.900.152 crashes when Protected Mode Enabled
                          gh0stmaster Level 1
                          Im using 11.9.900.152, but let me know how it goes!
                          • 11. Re: Flash 11.9.900.152 crashes when Protected Mode Enabled
                            Thanks.  I'm not able to reproduce it there, either.  I'll keep poking at it.
                            • 12. Re: Flash 11.9.900.152 crashes when Protected Mode Enabled
                              gh0stmaster Level 1
                              Thanks, in the mean time Ill have to use protected mode disabled, or chrome
                              • 13. Re: Flash 11.9.900.152 crashes when Protected Mode Enabled
                                Given the age of this discussion, and the fact that the last post was related to Internet Explorer and an operating system that didn't even exist when this thread was created, I'm going to close it.  This will prevent the folks on this thread from getting additional random email updates.
