2 Replies Latest reply: Nov 16, 2013 5:55 PM by xmikal65x RSS
    Hardware Specifics Check - (Preview Window Choppy)
    xmikal65x Community Member
      So I upgraded from CS6 to CC and what use to play smoothly in the preview window is now playing choppy. What I have discovered is that if I loop the troubled spot 1-6 times, it plays smoothly and will so long as the project is open. After the project is closed and reopened, it resets and all the footage starts smooth for 1-3 seconds, and then bogs down. This is with the preview monitor's resolution set to the lowest. I really hope it's not my hardware, but if someone would care to verify my specs, that would be great.
      OS: Windows 8.1
      Graphics: XFX DD Radeon R7970 3GB DDR5, 384 bit BUS, GPU Clock 925MHz Memory 1375MHz
      CPU: Intel i7-3820 CPU @3.6GHz (8 CPUs)
      Memory: 64 GB DDR3
      Disk: 7200 rpm connected through Sata and USB 3.0
      The problem is not limited to HD formats, I can't even preview standard definition formats without choppy playback 2-3 seconds in.
      I've also adjusted the render paramater between PERFORMANCE and MEMORY, both equally seem to deliver the same results.
      It's a bummer because I was able to edit RED footage without a problem, now it's just ridiculous.
