6 Replies Latest reply on Feb 17, 2014 6:13 PM by OnTheBallWebDesigns
    Hide web app field in detailed view
    OnTheBallWebDesigns
      Hello
      Is there a way to hide empty we app fields in detailed view. Working on a boat listing site with quite a few fields and want to exclude the field if the customer doesn't add any info.
      http://uguru-autodealer-au21.businesscatalyst.com/boat-listings/43-custom-timber-trawler
      I understand that java can do this however I am not fluent with this.
      Thank You
        • 1. Re: Hide web app field in detailed view
          Alex Pavelescu Adobe Employee
          BC doesn't offer this as an out-of-the-box feature. You'll have to use a little scripting to hide those fields. I see you're using a list in your detail template for the respective webapp. If you were to use a table instead, you'd have this easy workaround: http://jsfiddle.net/A4Wgk/1/. This is just one suggestion though, there are many variations/approaches depending on what html elements you're using to display the data in the first place.
          Kind REgards,
          Alex Pavelescu
          • 2. Re: Hide web app field in detailed view
            OnTheBallWebDesigns Level 1
            Hello Alex
            Thank you for your reply.
            I have tried to add your script to my template but still showing the empty rows.
            http://uguru-autodealer-au21.businesscatalyst.com/boat-listings/Buzzcat
            I put the javaScript up in the head section, not sure if this is the problem. Have added code below.
            <!DOCTYPE html>
            <html lang="en" class="no-js">
                <!--<![endif]-->
                <head>
                    <meta charset="utf-8" />
                    <meta content="width=device-width, initial-scale=1.0, minimum-scale=1.0" name="viewport" />
                    <title>{tag_name}</title>
                    <link href="/favicon.png" rel="shortcut icon" />
                    <link href="/home_badge_64.png" rel="apple-touch-icon" />
                    <link href="/home_badge_64.png" rel="apple-touch-icon-precomposed" />
                    <link href="/_assets/css/normalize.css" rel="stylesheet" />
                    <link href="/_assets/css/foundation.css" rel="stylesheet" />
                    <link href="/_assets/css/styles.css" rel="stylesheet" />
                    <script src="/_assets/js/custom.modernizr.js"></script>
                    <script>
            $('td:last-child:empty').parent().hide();
            </script>
                </head>
                <body>
                // Will retun 1 or 0 based on if user is logged in(1) or not logged in(0)
                var _isLoggedIn = !!parseInt("{module_isloggedin}");
                </script>
                    <header>
                    <section>
                    <div class="row alpha">
                    <div class="large-12 columns">
                    {module_menu, version="2", menuId="625382", moduleTemplateGroup="UtilityNav"}
                    </div>
                    <!-- end .columns.large-12 -->
                    </div>
                    <!-- end .row -->
                    </section>
                    <div class="row">
                    <div class="large-12 columns contain-to-grid">
                    {module_menu, version="2", menuId="625379", moduleTemplateGroup="Primary"}
                    </div>
                    </div>
                    <!-- end .row -->
                    </header>
                    <!-- end header -->
                    <div class="wrapper">
                    <div class="unhero"></div>
                    <div class="row pagetitle">
                    <div class="column large-12">
                    <h1 class="left">{tag_name}</h1>
                    </div>
                    <!-- end .column.large-12 -->
                    </div>
                    <!-- end .row.pagetitle -->
                    <div class="row supersize">
                    <div class="row">
                    <div class="columns large-6">
                    <div id="inner-slider">
                    <ul data-orbit="data-orbit">
                        {tag_image 1}{tag_image 2}{tag_image 3}{tag_image 4}{tag_image 5}{tag_image 6}{tag_image 7}{tag_image 8}</ul>
                        <div class="mpgs panel">
                        <span class="mpg">MDBS: {tag_office}</span><span class="mpg"></span>
                        </div>
                        <h3>Boat Information</h3>
                        <p><strong>Description:</strong><br />
                        {tag_description}</p>
                        <p><strong>Dealer Info:</strong><br />
                        </p>
                        <br />
                        </div>
                        </div>
                        <!-- end .columns large-6 -->
                        <h2 class="alt"><small><del></del></small>  {tag_currency} $<span class="tprice">{tag_price} <br />
                        </span></h2>
                        <table cellpadding="10" style="border-bottom: 1px dotted #b7b9b1; width: 470px; border-top: 1px dotted #b7b9b1;">
                            <tbody>
                                <tr>
                                    <td class="TableFields">Who Should Enroll?:</td>
                                    <td>EveryOne</td>
                                </tr>
                                <tr>
                                    <td class="TableFields">Location:</td>
                                    <td>Los Angeles</td>
                                </tr>
                                <tr>
                                    <td class="TableFields">Location Notes:</td>
                                    <td> </td>
                                </tr>
                                <tr>
                                    <td class="TableFields">Public Transportation:</td>
                                    <td>Yes</td>
                                </tr>
                                <tr>
                                    <td class="TableFields">Handicapped Access:</td>
                                    <td>N/A</td>
                                </tr>
                                <tr>
                                    <td class="TableFields">Parking Notes:</td>
                                    <td> </td>
                                </tr>
                                <tr>
                                    <td class="TableFields">Instructor:</td>
                                    <td>Jim Lafford</td>
                                </tr>
                            </tbody>
                        </table>
                        <hr />
                        <h3>More Info</h3>
                        <p><strong>Downloadable Details: </strong>{tag_downloadable details}  </p>
                        <hr />
                        <h3>Loan Calculator</h3>
                        {module_contentholder, name="_Template - Loan Calculator"}
                        </div>
                        </div>
                        <!-- end .row -->
                        </div>
                        </div>
                        <!-- end .row.supersize -->
                        </div>
                        <!-- end .wrapper -->
                        <footer>
                        <div class="row collapse">
                        <div class="columns large-4">
                        {module_contentholder, name="_Template - Help Center"}
                        </div>
                        <!-- end .columns.large-4 -->
                        <div class="columns small-6">
                        {module_contentholder, name="_Template - My Account"}
                        </div>
                        <!-- end .columns.small-6 -->
                        {module_contentholder, name="_Template - Privacy"}
                        </div>
                        </div>
                        {module_contentholder, name="_Template - About Us"}
                        </div>
                        <!-- end .search -->
                        </div>
                        <!-- end .row.collapse -->
                        <div class="row collapse omega">
                        <p>{module_webapps,0,i,6651 template="/_settings/copyright"} - {module_webapps,0,i,6651 template="/_settings/company-name"}</p>
                        </div>
                        <!-- end .columns.large-6 -->
                        {module_menu, version="2", menuId="625381", moduleTemplateGroup="Social"}
                        </div>
                        </div>
                        </footer>
                        <!-- end footer -->
                        {module_contentholder, name="_Template - Scripts"}
                    </body>
                </html>
            Thank you in advance.
            Regards
            Valentino
            • 3. Re: Hide web app field in detailed view
              Hi Valentino,
              Just 2 issues to cover:
              - Make sure you reference jquery
              - Make sure you change the respective webapp's detail layout so it actually contains table elements, as you're currently using a list: http://screencasteu.worldsecuresystems.com/AP/2013-12-02_1257.png
              Here's a working example:
              http://screencasteu.worldsecuresystems.com/AP/2013-12-02_1251.swf
              Kind Regards,
              Alex
              • 4. Re: Hide web app field in detailed view
                Alex you are a champ!
                Thank you for your time to guide me through this, was very helpful and has been implemented on the site perfectly.
                Regards
                Valentino
                • 5. Re: Hide web app field in detailed view
                  Hello Alex
                  Thank you for your help so far, I have run in a little trouble with the hide features script.
                  Site is now live:
                  www.mdbs.com.au
                  </script>
                              <script>
                  </script>
                  When I add the Recaptcha V2 it hides the fields because its a table.
                  Recaptcha V1 has been getting heaps of spam unfortunatley.
                  Was thinking there could be a way to just div up the table I want to use the script for and not the whole page.
                  I had to take out the contact form with the captcha 1 as too much spam was sent through.
                  Any advise would be appreciated.
                  Regards
                  Valentino
                  • 6. Re: Hide web app field in detailed view
                    Worked this one out..
                    Wrapped the table I wanted to target in a <div> tablez and used the following script:
                    <script>
                    $('#tablez table td:last-child:empty').parent().hide();
                    </script>
                    Now works.
