1. Re: Query problem when switching from Access to MS SQL
REEDPOWELL Dec 1, 2013 1:19 PM (in response to weezerboy)MS SQL does not allow you to use aliased columns as operands in other elements of a SELECT statement. Each element of the SELECT list has to be based on an actual column, function result, subquery result, etc.
-reed
2. Re: Query problem when switching from Access to MS SQL
BKBK Jan 19, 2014 1:30 AM (in response to weezerboy)ReedPowell is right. You could just do something like
SELECT e.wall +l.wall As wall2yr, e.lall +l.lall As lall2yr, l.TEAMID, l.TEAMNAME, l.GY AS LaterGY, l.finalrating, e.finalrating, e.GY AS EarlyGY, l.finalrating + e.finalrating AS twoyear FROM TEAMSEASONRATINGINFO AS e INNER JOIN TEAMSEASONRATINGINFO AS l ON l.teamID = e.TeamID AND l.GY = e.GY+1 WHERE l.GY =#url.GY# AND e.finalrating > 0
AND l.DIVISION = #url.DIVISION#
ORDER BY e.finalrating+ l.finalrating DESC
You should also make your code less vulnerable to hacking by replacing #url.GY# and #url.DIVISION#, respectively, with <cfqueryparam value="#url.GY#" cfsqltype="cf_sql_varchar"> and <cfqueryparam value="#url.DIVISION#" cfsqltype="cf_sql_varchar">.
