1 Reply Latest reply on Dec 18, 2007 10:15 PM by Amebr-ke0mH4
    Robohelp 5 Runtime Error
    Joyeuse13
      One of my employees has reported the following error:
      Microsoft Visual C++ Runtime Library
      This application has requested the Runtime to terminate it in an unusual way.
      She says she gets this every time she opens RH. We have tried reinstalling RH but the error persists.
      We use Windows XP, IE 6, RH version 5. Has anyone run into this before?
      Joyce
        • 1. Robohelp 5 Runtime Error
          Amebr-ke0mH4 Level 2
          I had issues with something like this and the CiceroUIWndFrame issue here ( http://tinyurl.com/2522ao)
          My first thought is about your user having Admin access to the PC, and also checking to make sure they have write access to the PC (yes, somehow a collegue was given read only access to C drive... ). If the user doesn't have Admin access, you might need to uninstall and re-install RH - Rick or someone else might be able to confirm if this is necessary.
          Also, I remember something about Handwriting and Speech options and Data Execution Prevention. (Sorry I'm being so vague - there were a number of issues that all cropped up at the same time, and I can't remember which order they occured.)
          I can't find my notes, but I think I uninstalled the Handwriting and Speech options in Office, as we don't use them anyway.
          I can't remember what I did for DEP. Data Execution Prevention is under Control Panel > System > Advanced tab > Performance Settings. I think it was only a problem of PCs that supported hardware DEP (there is a note at the bottom of the window if the PC DOESN'T support hardware DEP), and I specified RH as an exception? But I'm not 100% certain of this.
