1 Reply Latest reply: Nov 16, 2013 2:56 PM by Stan Jones RSS
    audio in Encore is too short
    Brit.b Community Member
      When I export multiplexed audio it causes short audio in Encore. It works fine when not multiplexing as two separate files but I prefer to have it come in as one file as it is simpler for beginning students. Mpeg DVD multiplexing has worked without a hitch for years but somehow, sometimes (but not always) the audio comes in a couple seconds short on CS6. I have seen another thread on this subject, but it didn't have a solution other than not multiplexing. Since multiplexing is still an option, it should work.
        • 1. Re: audio in Encore is too short
          Stan Jones CommunityMVP
          Yes, multiplexing is supported, but it has always had sometimes where it did not work as expected. You apparently had better luck than many.
          Because Encore (any DVD authoring program) must de-multiplex such streams before it can build the vob containers, it has made sense to me to use the default/recommended method for MPEG2-DVD/MPEG2-Bluray/H264-Bluray - which is separate files for video and audio.
          Since some of the time you will get problem results, the choice is to teach mpeg and then how to redo the export to demuxed or to teach demuxed. Either is a legitimate option.
