This content has been marked as final.
Show 5 replies
1. Re: Object moving between identical keyframes
Peru Bob Nov 17, 2013 2:57 PM (in response to HakanErn)I've had that happen in CS5.5. My fix was to write down all of the keyframe properties, delete the existing keyframes, and apply new keyframes in consecutive order only.
2. Re: Object moving between identical keyframes
HakanErn Nov 17, 2013 3:07 PM (in response to Peru Bob)Thanks fo rreplying. It seems to be a very hard work...
There must be a reasin for this happening...
3. Re: Object moving between identical keyframes
JSS1138 Nov 17, 2013 6:56 PM (in response to HakanErn)Right click the keyframes and change the Spatial Interpolation to Linear.
4. Re: Object moving between identical keyframes
HakanErn Nov 18, 2013 3:17 AM (in response to JSS1138)Thank you!
5. Re: Object moving between identical keyframes
HakanErn Nov 18, 2013 5:27 AM (in response to JSS1138)Jim
I solved it where the first problem was, but now I am stuck again.
Even if I change both keyframes Spatial INterpolartion to "Linear" the object moves between two identical keyframes.UPDATE: It seems as if it was an updateing problem, when I selected another part of the timeline and then want back to the "problem" it was solved... Thought it should update immediatly?
/H
