2 Replies Latest reply on Nov 18, 2013 5:32 PM by A.T. Romano
    Assistance Setting Presets for Exporting to .FLV
    Jesse_Martinez(Calvary)
      I need assistance in customizing the presets for exporting a file to .flv format. Here is what I need Abode to export TO:
      .flv
      320x240
      4:3
      800kbps
      29-97 fps
      audio - 44 khz 66kbps stereo
        • 1. Re: Assistance Setting Presets for Exporting to .FLV
          A.T. Romano Level 7
          I have been working on this and intending to get back to you later today.
          For the .flv, so far so good, except....closest audio bitrate is 64 kbps (kilobits per second)....can do on the Stereo, but the sampling rate kHz is going to be 22.05 and not 44. I am not seeing any way to set that otherwise...that is what has delayed my response.
          If we went the .f4v route, we can set the sampling rate at 44.1 kHz.
          Is f4v a consideration?
          Thanks.
          ATR.
          • 2. Re: Assistance Setting Presets for Exporting to .FLV
            A.T. Romano Level 7
            Your requirements are stated as
            .flv
            320x240
            4:3
            800kbps
            29-97 fps
            You can accomplish nearly all in Premiere Elements 12, but there is a problem achieving the exact audio sampling rate/bitrate combination that you list.
            In Premiere Elements 12, go to Publish+Share/Computer/Adobe Flash Video and select Presets = FLV - Web Large NTSC Source (Flash 8 or Higher)  On2VP6 MP3 FLV
            Under the Advanced Button/Video Tab, make adjusts
            Remove the link between Frame Width and Height and type in
            Frame Width = 320
            Frame Height = 240
            Bitrate = 800 kbps (kilobits per second)
            Under the Advanced Button/Audio Tab, make adjusts
            Output Channel = Stereo
            Bitrate Settings - now here is where it get tricky...there is no set for sampling rate/frequency = 44 KHz or other. And, there is no audio bitrate of 66 kbps (closest is 64 kbps), There appears to be a sampling rate associated with the export, but viewable once you have the export and look at its properties in a program such as MediaInfo.
            Here is what I found
            if the audio bitrate = 64 kbps, then the sampling rate is 22.05 KHz
            if the audio bitrate = 80 kbps, then the sampling rate is 22.05 KHz
            if the audio bitrate = 96 kbps, then the sampling rate is 44.1 KHz
            if the audio bitrate = 128 kbps, then the sampling rate is 44.1 KHz
            Are there trade offs for you or must you have those exact values that you posted?
            H.264 AAC F4V
            If you were to export your Timeline as F4V, then you would have the opportunity to set sampling rate 44.1 KHz and bitrate 64 kbps.
            We can discuss other not mentioned settings later once we have worked through the core ones.
            Please review.
            Thanks.
            ATR
