1 Reply Latest reply on Nov 19, 2013 2:11 PM by Michael Thornburgh
    Adobe Cirrus returns no result
    Saulo S. Toledo Level 1
      I'm new with Cirrus. I have this code in my aplication:
      this.netConnection = new NetConnection();
      this.netConnection.addEventListener(NetStatusEvent.NET_STATUS, netConnectionHandler);
      this.netConnection.connect(CirrusAddress, DEVELOPER_KEY);
      The DEVELOPER_KEY is correctly defined, and CirrusAddress is
      protected const CirrusAddress : String = "rtmfp://p2p.rtmfp.net/";
      I'm receiving this error at last line (connect line):
      HTTP response has no result
      I don't understood why, since I'm using the correct dev key and cyrrus address. Since I can't connect at cyrrus service, all my code don't works.
      Player information: "Capabilities.version" prints "LNX 11,7,700,169".
      I'm using Apache Flex 4.9.0 on GNU/Linux.
      Thanks in advance.
        • 1. Re: Adobe Cirrus returns no result
          Michael Thornburgh Adobe Employee
          i don't see any HTTP in your code above. that error must be coming from a different code path.
          are you using the VideoPhoneLabs sample application or a brand new app of your own?  are you trying to access any HTTP resources elsewhere in your code?  are you using ActionScript 2 somehow?  AS2 does not support RTMFP, if i remember correctly.
