0 Replies Latest reply on Aug 10, 2006 12:46 PM by NativeShore
    Repeat Region problem
    NativeShore
      Hi. Thanks for reading.
      I have this problem where the repeated region (a table) is not working properly. When it loads, each record is repeated 4 times before the next record appears. It was working fine originally.
      I believe the problem started when I added arow and move things around. After I did that, the repeat region code began to double each record. I then removed it and replaced it and now the problem is twice as bad... literally. Has anyone encountered this.
      I've attached the code. I hope someone can help.
      thanks again.
      zp
