4 Replies Latest reply on Jan 1, 2008 10:32 PM by Newsgroup_User
    Flex Builder for Linux install error
    nobu@fxug Level 1
      Hi.
      An error occurs at the time of Flex Builder for Linux installation.
      nobu@nobu-mob:~/downloads/adobe/flex3> sh flexbuilder_linux_install_a2_121807.bin
      Preparing to install...
      Extracting the installation resources from the installer archive...
      Configuring the installer for this system's environment...
      Launching installer...
      Exception in thread "main" Exception while printStackTrace(): java.lang.NoClassDefFoundError: java/lang/System
      Why is it?
      ■Environment
      ・Linux
      openSUSE 10.3
      ・Java
      nobu@nobu-mob:~/downloads/adobe/flex3> java -version
      java version "1.5.0_12"
      Java(TM) 2 Runtime Environment, Standard Edition (build 1.5.0_12-b04)
      Java HotSpot(TM) Client VM (build 1.5.0_12-b04, mixed mode, sharing)
      ・JAVA_HOME
      JAVA_BINDIR=/home/nobu/application/java/bin
      JAVA_HOME=/home/nobu/application/java
      JAVA_ROOT=/home/nobu/application/java
      ・CLASSPATH
      CLASSPATH=.:/home/nobu/application/java/jre/lib:/home/nobu/application/java/lib:/home/nobu /application/java/lib/tools.jar:/home/nobu/application/tomcat/common/lib:/home/nobu/applic ation/tomcat/common/lib/servlet-api.jar
        • 1. Re: Flex Builder for Linux install error
          nobu@fxug Level 1
          Hi
          It was a setting error of CLASSPATH.
          Thank you for all
          • 2. Re: Flex Builder for Linux install error
            Ricksmth51 Level 1
            I'm also getting a class not found exception. The part of the output is
            Caused by: java.lang.ClassNotFoundException: com.apple.mrj.MRJOSType not found in [file:/tmp/install.dir.29782/InstallerData/, file:/tmp/install.dir.29782/InstallerData/installer.zip.
            I'm puzzled by the path it's looking in which I would think would be for OS/X not Linux. Does this class belong in the build? TIA.
            • 3. Re: Flex Builder for Linux install error
              felix.rivas Level 1
              hi daring me this error installation, Ubuntu 7.10:
              "Preparing to install...
              No Java virtual machine could be found from your PATH
              environment variable. You must install a VM prior to
              running this program."
              • 4. Re: Flex Builder for Linux install error
                Level 7
                Your path has to be set properly...
                Install SUN JRE ...Set the path and launch the installer..
                $>export PATH=$HOME/j2sdk1.5.xx/bin:$PATH
                $>sh Adobe_Flex_Builder.bin
