3 Replies Latest reply on Nov 20, 2013 7:26 AM by Ghoulfool
    Adding a layer, filling it and removing it again
    loopstar
      Hi
      I am trying to understand scripting, but I guess I am not getting it.
      I have script made by Paul Riggott (thank you, again Paul) which takes a png icon and makes the three versions I need the file in for our desktop java application.
      Now I need a diffferent version of the script for some of these icons, where a opaque background is added in the "h" version. This is for mouse hovering over the icon, giving it a bit more button-feel.
      I have been hacking and stealing script-bits from around the forum, and of course it is not working.
      Here's the code:
      #target photoshop
      main();
      function main(){
      var inFolder = Folder.selectDialog("Please select folder to process");
      var fileList = inFolder.getFiles("*.png");
      if(fileList.length == 0 ) return;
      var outputFolder = Folder (inFolder+"/Commit icons");
      if(!outputFolder.exists) outputFolder.create();
      for(var a in fileList){
      var png = open(fileList[a]);
      var Name = app.activeDocument.name.replace(/\.[^\.]+$/, '');
      var saveFile = File(outputFolder + "/" + Name + "_16_n_p.png");
      SavePNG(saveFile);
      //stuff I added
      activeDocument.artLayer.add();
      var myColor = new SolidColor();
      myColor.rgb.red = 160;
      myColor.rgb.green = 160;
      myColor.rgb.blue = 160;
      activeDocument.selection.fill( myColor);
      docRef.artLayers[0].move(docRef.artLayers[docRef.artLayers.length-1], ElementPlacement.PLACEAFTER);
      saveFile = File(outputFolder + "/" + Name + "_16_h_p.png");
      SavePNG(saveFile);
      activeDocument.activeLayer.remove;
      //end of stuff I added
      activeDocument.activeLayer.opacity=60;
      activeDocument.changeMode(ChangeMode.GRAYSCALE);
      saveFile = File(outputFolder + "/" + Name + "_16_d_p.png");
      SavePNG(saveFile);
      app.activeDocument.close(SaveOptions.DONOTSAVECHANGES);
      function SavePNG(saveFile){
          pngSaveOptions = new PNGSaveOptions();
      activeDocument.saveAs(saveFile, pngSaveOptions, true, Extension.LOWERCASE);
      I hope someone can help me with this, and maybe even explain what I am doing wrong.
        • 1. Re: Adding a layer, filling it and removing it again
          loopstar Level 1
          this made it work:
          #target photoshop
          main();
          function main(){
          SavePNG(saveFile);
          activeDocument.artLayers.add();
          activeDocument.artLayers[0].move(activeDocument.artLayers[activeDocument.artLayers.length- 1], ElementPlacement.PLACEAFTER);
          SavePNG(saveFile);
          activeDocument.activeLayer.remove();
          SavePNG(saveFile);
          • 2. Re: Adding a layer, filling it and removing it again
            loopstar Level 1
            Wish I could give "correct" to my self, as I feel like a superstar right now :-)
            • 3. Re: Adding a layer, filling it and removing it again
              Ghoulfool Level 1
              You're nearly there:
              #target photoshop
              main();
              function main(){
              SavePNG(saveFile);
              //stuff I added
              var layerRef = app.activeDocument.artLayers.add()
              layerRef.name = "fill";
              // Move the new layer after the current layer
              var id3870 = charIDToTypeID( "move" );
              var desc660 = new ActionDescriptor();
              var id3871 = charIDToTypeID( "null" );
              var ref421 = new ActionReference();
              var id3872 = charIDToTypeID( "Lyr " );
              var id3873 = charIDToTypeID( "Ordn" );
              var id3874 = charIDToTypeID( "Trgt" );
              ref421.putEnumerated( id3872, id3873, id3874 );
              desc660.putReference( id3871, ref421 );
              var id3875 = charIDToTypeID( "T   " );
              var ref422 = new ActionReference();
              var id3876 = charIDToTypeID( "Lyr " );
              ref422.putIndex( id3876, 0 );
              desc660.putReference( id3875, ref422 );
              var id3877 = charIDToTypeID( "Adjs" );
              desc660.putBoolean( id3877, false );
              executeAction( id3870, desc660, DialogModes.NO );
              //app.activeDocumentdocRef.artLayers[0].move(docRef.artLayers[docRef.artLayers.length-1], ElementPlacement.PLACEAFTER);
              SavePNG(saveFile);
              SavePNG(saveFile);
