2 Replies Latest reply on Nov 20, 2013 6:38 AM by florin.popa1986
    moving all layers into a single layer
    florin.popa1986
      Hello,
      I'm new in scripting and i need to make a script that moving all layers into a single layer( in Illustrator i press CTRL+A then CTRL+G in layers and works) but i need that in script
      Please could somebody help me?
      Thanks!
        • 1. Re: moving all layers into a single layer
          florin.popa1986 Level 1
          i try this function but is different (ctrl A + ctrl G does something else)
          main();
          function main() {
                    if ( app.documents.length == 0 ) { return; }
                    app.userInteractionLevel = UserInteractionLevel.DONTDISPLAYALERTS;
                    var doc = app.activeDocument;
                    var mast = doc.layers.add();
                    mast.name = 'original';
                    for ( var  i = doc.layers.length-1; i >= 1; i-- ) {
                              doc.layers[i].move( mast, ElementPlacement.PLACEATBEGINNING )
          • 2. Re: moving all layers into a single layer
            i found the solution
            function main() {
            var grup=mast.groupItems.add();
            //   var pageIt=mast.pageItems.add();
            while (doc.layers.length > 1)
            while (doc.layers[doc.layers.length - 1].pageItems.length)
            doc.layers[doc.layers.length - 1].pageItems[doc.layers[doc.layers.length - 1].pageItems.length - 1].move( grup, ElementPlacement.PLACEATBEGINNING );
            doc.layers[doc.layers.length - 1].remove();
