3 Replies Latest reply on Feb 13, 2014 3:30 AM by Switcher102
    Photoshop CS2 Activation
    footix2
      We are upgrading one of our workstations and the user has PS CS2 installed.
      Rather than upgrade to a newer version, and because CS2 is sufficient for our fairly simple needs I attempted to install it on the new Windows 8.1 system.
      The software is compatible with this OS, but when attempting to activate I got a message that the activation servers for this software are no longer available. Upon visiting Adobe.com I found that you can download a copy of CS2 and use the serial number found on the case and activate the software that way.....
      ...only I can't! When try to use the serial number I have used in the past, the software says it's not valid.
      So I am a bit stuck now. I have software that I can longer use, and find out how to contact Adobe to sort this is a task in itself. I suspect they will just feed me the "no-longer supported" line anyway.
      Am I missing something? Anybody else came across this problem?
