2 Replies Latest reply on Nov 20, 2013 1:42 PM by Todd_Kopriva
    Some questions about settings/quality/rendered clips/slowmo
    Brissee
      So I need some help as This weekend I will do a movie project and want to do the best out of it.
      so Im using a Canon EOS 600D. the two programs I will be using is AAE CC & Premiere Pro CC.
      1. What would you recommend me to to, Edit the clips with effects/cc/slowmo and so on in after effects clip by clip and then sync and put all together in premiere pro? Or is it any smoother way to do it?
      2. Of cource I want the maximum quality and my question is what I should use for settings. I got a pretty beast computer so I dont care really to keep it to a small file.(Its going on to youtube btw). Is there any codec I should download or anything? uncompressed is the best quality I guess but it should different uncompressed codecs?
      3. Will I get less quality if I first render a clip in after effects and when I got all the clips done in premiere and rendering everything there?
      4. As 600D only record in 30fps, will a slowmo look bad? I will be using twixtor. as often you want 60fps while doing slowmo effects.
      Sorry if Im unclear. feel free to ask if you dont understand or so on.
      I would appreciate answers, thanks
        • 1. Re: Some questions about settings/quality/rendered clips/slowmo
          Dave LaRonde Level 7
          The Most Important Question:  how slow is slow?  Half the normal speed?  So slow you can see a bullet passing through an apple?
          It makes a difference.
          • 2. Re: Some questions about settings/quality/rendered clips/slowmo
            Todd_Kopriva Level 8
            That depends on a lot of factors. I'm going to presume that you are going to shoot way more video than you need. If this is so, then you don't want to process a bunch of footage in After Effects that you're not going to need. That's why you should do your rough cut in Premiere Pro and then just send the little pieces over to After Effects that you're actually using.
            For your final render, you should be going through Adobe Media Encoder and using the built-in YouTube encoding presets.
            For your intermediate files, you have a lot of choices. Personally, I use QuickTime movies with the PNG codec as intermediate files between the NLE (Premiere Pro) and the compositing application (After Effects). ProRes 4444 is another adequate option, even though it's slightly lossy. There are many other choices. Just don't use a format that compresses a lot for your intermediate files---e.g., don't use H.264.
            No. The reasons for chooisng one workflow over another are for efficiency, not for quality.
            Why? What's wrong with the Timewarp effect and time remapping built into After Effects?
