2 Replies Latest reply on Nov 21, 2013 5:10 AM by Peter Spier
    Why Can I Only "Save As" ?
    TommyMc3
      I hve always been able to quick save "Ctrl+S" but for some reason i can only "Save As" now...i think i might have hit something on my keyboard to disable the feature...does anyone have a clue how to reactivate it?
        • 1. Re: Why Can I Only "Save As" ?
          Doc Maik Level 4
          All keyboard shortcuts can be modified via menu EDIT->KEYBOARD SHORTCUTS. Ctrl+S is usually assigned to "Save", but be removed here.
          Try to assign it again and see if it works.
          • 2. Re: Why Can I Only "Save As" ?
            It's normal for you to see the Save As dialog the first time you open a legacy file in a newer version of ID, or the first time you save a new file or a .idml/.inx file, or one created from a template (and even some files that come in on removeable media because they are marked Read Only), but if subsequent uses of Ctrl + S are bringing up the Save As dialog it's more likely a prefs problem than a problem with the shortcut set (but it never hurts to check, and that's the first thing I'd do). If it's not the shortcut, next step would be to replace the prefs. See Replace Your Preferences
