0 Replies Latest reply on Nov 21, 2013 7:29 AM by ashar2005
    RTMP in Coldfusion10 - Type 'coldfusion.flash.messaging.CFRTMPEndPoint' not found
    ashar2005
      I'm trying to use RTMP with Coldfusion 10 and the embedded livecycle ES.  The other channels and endpoints
      have been working fine, but when the server starts up I get an error complaining that the endpoint cannot be
      found for the cf-rtmp channel.   I'm using the standard setup with no special configuration.
      The AMF channel, polling channel, etc. work just fine, and there are no complaints
      about those channels or endpoints when the server starts up.
      This is the error in the logs when the server starts up:
      INFO: ColdFusionStartUpServlet: ColdFusion: VM version = 23.7-b01
      java.lang.NullPointerException
                at coldfusion.server.jrun4.metrics.SimpleLoadMetric.run(SimpleLoadMetric.java:157)
                at coldfusion.scheduling.ThreadPool.run(ThreadPool.java:211)
                at coldfusion.scheduling.WorkerThread.run(WorkerThread.java:71)
      Nov 21, 2013 9:34:14 AM org.apache.catalina.core.ApplicationContext log
      INFO: CFMxmlServlet: Macromedia Flex Build: 87315.134646
      **** MessageBrokerServlet in application 'Adobe ColdFusion 10' failed to initialize due to runtime exception:   Exception: flex.messaging.MessageException: Cannot create class of type 'coldfusion.flash.messaging.CFRTMPEndPoint'. Type 'coldfusion.flash.messaging.CFRTMPEndPoint' not found.
                at flex.messaging.util.ClassUtil.createClass(ClassUtil.java:70)
      Here is the channel definition in my services-config file:
      <channel-definition id="cf-rtmp" class="mx.messaging.channels.RTMPChannel">
                <endpoint uri="rtmp://{server.name}:2048" class="coldfusion.flash.messaging.CFRTMPEndPoint"/>
                    <properties>
                      <idle-timeout-minutes>20</idle-timeout-minutes>
                              <serialization>
                                  <enable-small-messages>false</enable-small-messages>
                              </serialization>
                 <coldfusion>
                           <access>
                                          <use-mappings>true</use-mappings>
                                    <method-access-level>remote</method-access-level>
                                </access>
                                <use-accessors>true</use-accessors>
                                <use-structs>false</use-structs>
                                <property-case>
                                 <force-cfc-lowercase>false</force-cfc-lowercase>
                                    <force-query-lowercase>false</force-query-lowercase>
                                    <force-struct-lowercase>false</force-struct-lowercase>
                                </property-case>
                  </coldfusion>
                    </properties>
      </channel-definition>
