1. Re: available web fonts
sarhunt Nov 24, 2013 10:11 PM (in response to AMULI)Hi Gil,
The fonts in the Edge Web Fonts panel are pulled from https://edgewebfonts.adobe.com/ which contains a wide sampling - not not all of - those found on Google Web Fonts.You can use whatever web font you'd like by using the custom fonts tab:
Sarah
2. Re: available web fonts
AMULI Nov 25, 2013 1:45 AM (in response to sarhunt)Thanks Sarah,
I have indeed used the custom tab to copy and paste the code from Google Fonts and even copied 'ABeeZee', sans-serif as the Font Fallback List.
Naively, I thought the built-in panel was an interface to the whole free inline fonts :-)
Gil
3. Re: available web fonts
AMULI Nov 25, 2013 8:21 AM (in response to sarhunt)Hi Sarah,
In the main font I use, digits have too different widths, so I use another one, monospaced, for the year intervals in an accordion to have even widths.
Flash allows to embed only a subset of glyphs. Is there a way to restrain the loading for the second font only to the ten digits and a dash ? Thanks :-)
Gil
4. Re: available web fonts
elainefinnell Nov 25, 2013 10:18 AM (in response to AMULI)Hey, Gil-
Unfortunately, it's highly dependent on the service that serves the fontpack. Google generally separates the fonts into Latin and Latin-extended, but it doesn't go any more granular than that. You could probably create your own fontpack using a service like FontSquirrel and use local CSS to refer to it.
Hope that helps,
-Elaine
