7 Replies Latest reply on Nov 25, 2013 6:31 AM by oberen
      • 1. Re: Crashes at launch.
        ibarrien Adobe Employee
        is this an official update or have you updated it manually?
        thanks,
        Ignacio
        • 2. Re: Crashes at launch.
          oberen Level 1
          nope - custom stock-based.
          But PS works fine on 4.3.1 custom non-stock-based (Carbon if you intresting).
          • 3. Re: Crashes at launch.
            ok,
            what normally has been the case once people start to update to custom roms is that they have problems with the fonts.
            If you have one that works they probably add the fonts. For the rom that has issues - they probably don't.
            If you can send me the crash log from adb privately I can give it a look to let you know if it is the same thing.
            thanks,
            Ignacio
            • 4. Re: Crashes at launch.
              oberen Level 1
              Hi.
              I've to figure out how to add contact to send pm, but i don't get it.
              Here's my logcat since i'm so dumb.
              As i saw problem in droid sans?
              --------- beginning of /dev/log/main
              I/ActivityManager(  628): START u0 {act=android.intent.action.MAIN cat=[android.intent.category.LAUNCHER] flg=0x10200000 cmp=air.com.adobe.pstouchphone/.AppEntry} from pid 1095
              D/audio_hw_primary(  178): out_set_parameters: enter: usecase(1: low-latency-playback) kvpairs: routing=2
              D/audio_hw_primary(  178): select_devices: out_snd_device(2: speaker) in_snd_device(0: )
              D/ACDB-LOADER(  178): ACDB -> send_afe_cal
              I/ActivityManager(  628): Start proc air.com.adobe.pstouchphone for activity air.com.adobe.pstouchphone/.AppEntry: pid=28802 uid=10207 gids={50207, 3003, 1028, 1015}
              I/dalvikvm(28802): Enabling JNI app bug workarounds for target SDK version 12...
              V/PhoneStatusBar(  896): setLightsOn(true)
              I/StartupTime1(28802): :1385387276313
              D/dalvikvm(28802): Trying to load lib /mnt/asec/air.com.adobe.pstouchphone-1/lib/libCore.so 0x41efa198
              W/linker  (28802): libCore.so has text relocations. This is wasting memory and is a security risk. Please fix.
              D/dalvikvm(28802): Added shared lib /mnt/asec/air.com.adobe.pstouchphone-1/lib/libCore.so 0x41efa198
              W/libc    (28802): WARNING: generic atexit() called from legacy shared library
              D/StartupTime2(28802): :1385387276823
              D/skia    (28802): ---- failed to open </system/fonts/DroidSans.ttf> as a font
              D/skia    (28802): ---- failed to open </system/fonts/DroidSans-Bold.ttf> as a font
              F/libc    (28802): Fatal signal 11 (SIGSEGV) at 0x00000004 (code=1), thread 28802 (be.pstouchphone)
              • 5. Re: Crashes at launch.
                Yep like always your ROM is missing the fonts.
                Please let the ROM creators know about this.
                You can also add the fonts manually - this thread tells you how to do it:
                http://forum.xda-developers.com/showthread.php?t=2173160
                Ignacio
                • 6. Re: Crashes at launch.
                  oberen Level 1
                  Thanks a lot.
                  I also send log to rom creator. But i try to fix this by myself, don't sure what will happen
                  • 7. Re: Crashes at launch.
                    oberen Level 1
                    Thanks again!!!!
                    Just put em i nsystem/fonts and everything works!!!
