2 Replies Latest reply on Dec 19, 2007 6:11 AM by Peter Farland
    dot net webservices
    robotechnohub
      Hi, after using the webservices tool on a dot net wsdl file i get this error trying to use the code, i can send wsdl and code if need be. This is on beta2, busy downloading beta3
      Error: Cannot find definition for type ' http://tempuri.org/::GetTreeNodesInXMLResult_type8'
      at mx.rpc.xml::XMLDecoder/decodeType()[E:\dev\flex_3_beta2\sdk\frameworks\projects\rpc\src\m x\rpc\xml\XMLDecoder.as:1549]
      at mx.rpc.soap::SOAPDecoder/decodeType()[E:\dev\flex_3_beta2\sdk\frameworks\projects\rpc\src \mx\rpc\soap\SOAPDecoder.as:637]
      at mx.rpc.xml::XMLDecoder/decode()[E:\dev\flex_3_beta2\sdk\frameworks\projects\rpc\src\mx\rp c\xml\XMLDecoder.as:154]
      at mx.rpc.soap::SOAPDecoder/decodeBody()[E:\dev\flex_3_beta2\sdk\frameworks\projects\rpc\src \mx\rpc\soap\SOAPDecoder.as:426]
      at mx.rpc.soap::SOAPDecoder/decodeEnvelope()[E:\dev\flex_3_beta2\sdk\frameworks\projects\rpc \src\mx\rpc\soap\SOAPDecoder.as:270]
      at mx.rpc.soap::SOAPDecoder/decodeResponse()[E:\dev\flex_3_beta2\sdk\frameworks\projects\rpc \src\mx\rpc\soap\SOAPDecoder.as:211]
      at generated.webservices::BaseTreeViewActions/processResult()[C:\RudyDev\flex\Flex Builder 3\FlexDatabaseTest\src\generated\webservices\BaseTreeViewActions.as:216]
      at mx.rpc::AsyncResponder/result()[E:\dev\flex_3_beta2\sdk\frameworks\projects\rpc\src\mx\rp c\AsyncResponder.as:73]
      at mx.rpc::AsyncRequest/acknowledge()[E:\dev\flex_3_beta2\sdk\frameworks\projects\rpc\src\mx \rpc\AsyncRequest.as:81]
      at DirectHTTPMessageResponder/completeHandler()[E:\dev\flex_3_beta2\sdk\frameworks\projects\ rpc\src\mx\messaging\channels\DirectHTTPChannel.as:381]
        • 1. Re: dot net webservices
          bluestix Level 1
          I was getting similar errors with XMLEncoding on M$ .NET webservices.
          Might have something to do with this bug:
          https://bugs.adobe.com/jira/browse/FB-11239
          • 2. Re: dot net webservices
            Peter Farland Level 3
            The best way to get WebService issues investigated is to log a bug at http://bugs.adobe.com/flex/.
            When logging WebService bugs, please include the WSDL, any wsdl imports or includes, any XML Schema imports, a snippet of how you're calling the WebService if it's an encoding bug with the request, or an HTTP capture of the SOAP response XML if it's an issue with decoding the response (as appears to be the case from your posting).
            Your bug appears to be an issue with the generated WebService Stub code as I'm guessing your WSDL makes use of nested schema imports. I believe this has been fixed recently.
            It's still worth logging a bug, however, just to be sure.
