1 Reply Latest reply on Nov 25, 2013 11:59 AM by Salah Fadlabi
    PDF Form Questions
    tcbarry
      First thank you in advance for any help you can give me, I'm working on a project for a class and I was wondering about the feasability of some actions when using a PDF Form in Indesign CS6.
      First I was wondering if there was a way of making a field where the user could insert a picture into the field so that they see it there not as an attatcment that is just given when submitted?
      Also is there a way to change the spacing based on the number of fields used so that if the user only inputs in three of the fields they are equally spaced?
        • 1. Re: PDF Form Questions
          Salah Fadlabi Level 5
          This feature it's not support inside indesign, but after you create the form export to PDF then open in Adobe LiveCycle and add image field.
          If I understand you, you can make a fixed text frames size with equal space and then check on Multiline and Scrollable.
