1. Re: Is it possible to load a URL on stage?
kglad Nov 25, 2013 12:20 PM (in response to EGBAR.Mary)not unless you're publishing an air app.
2. Re: Is it possible to load a URL on stage?
EGBAR.Mary Nov 27, 2013 7:19 AM (in response to kglad)Hi,
I'm making a "Welcome Kiosk" for our company lobby and will be using a touch
screen monitor for visitors to go. They can either go to The Phone
Directory, Go To our Web page, or view Our Videos. So I can't display our
webpage in a container on the stage?
With warmest regards,
Mary Crotteau
Graphic Design Specialist
Sunshine Makers, Inc./Simple Green
3. Re: Is it possible to load a URL on stage?
kglad Nov 25, 2013 12:52 PM (in response to EGBAR.Mary)for a kiosk you should be using a desktop air app. you can therefore use the HTMLLoader class to load a url into your app.
4. Re: Is it possible to load a URL on stage?
EGBAR.Mary Nov 27, 2013 7:19 AM (in response to kglad)Thank you.
I'll check out lynda.com <http://lynda.com> for help. So on our flat screen
monitor, Air should be able to function like a huge ipad and pull in Video,
A Phone list, and display our website within the stage?
Could you tell me, is HTML5 better for something like this or is Action
Script 3 better?
Mary Crotteau
5. Re: Is it possible to load a URL on stage?
kglad Nov 25, 2013 5:34 PM (in response to EGBAR.Mary)actionscript/flash is easier (unless you're much more comfortable with javascript/html/ajax or jquery) as long as your kiosk runs an os that supports adobe air.
6. Re: Is it possible to load a URL on stage?
EGBAR.Mary Nov 27, 2013 7:19 AM (in response to kglad)Thanks. I think our IT department will handle it since they do html/java/and
all that stuff except for action script/flash. I am a little desperate
though. I need to have this at least display a working clock for know and
the phone list, which will display fine once I get to it. Can you be so kind
and look at my horrible action script and help me get the clock to work
continuously and show minutes under 10 with a "0"? I just need to have
something to show for our Annual Management meeting.
Thank you sincerely for your time.
Code:
import flash.events.MouseEvent;
import flash.text.TextField;
import flash.text.Font;
import flash.text.TextFormat;
import flash.display.Sprite;
import flash.text.*;
import flash.filters.BitmapFilter;
import flash.filters.BitmapFilterQuality;
import flash.filters.BlurFilter;
import flash.display.Bitmap;
import flash.display.Loader;
import flash.net.URLRequest;
var link:URLRequest = new URLRequest("http://simplegreen.com/");
//ADD CONTAINERS
var containerStage:Sprite = new Sprite();
containerStage.tabChildren = false;
stage.addChild (containerStage);
//DATE TIMER
var my_date:Date = new Date();
var my_timer:Timer = new Timer(1000);//create a new timer that ticks every
second
my_timer.addEventListener(TimerEvent.TIMER, onTimer);
my_timer.start();
//MONTH AND DATE
var months:Array = ["Jan", "Feb", "Mar", "Apr", "May", "June", "Jul", "Aug",
"Sept", "Oct", "Nov", "Dec"];
var days:Array = ["Sun", "Mon", "Tues", "Wed", "Thurs", "Fri"];
var todayIs = (days[my_date.day] + "," + " " + months[my_date.month] +" " +
my_date.date + " " + my_date.fullYear);
trace(days[my_date.day] + "," + " " + months[my_date.month] +" " +
//Text Loader
var textLoader:URLLoader = new URLLoader();
textLoader.addEventListener(Event.COMPLETE, textLoaded);
textLoader.load(new URLRequest("assets/phoneList.txt"));
var ampm:String = new String();
var zero:String = new String();
if (my_date.hours<12) {ampm = "AM";
else{
ampm = "PM";
while(my_date.hours > 12){my_date.hours = my_date.hours - 12;
if(my_date.minutes < 10){zero = "0" + my_date.minutes;
else{
my_date.minutes;
function onTimer(e:TimerEvent):void {
//my_date = new Date();
trace(my_date.hours + ":" + my_date.minutes);
var myDateTextBox:TextField = new TextField;
myDateTextBox = new TextField();
// myDateTextBox = todayIs;
var dateStyle:TextFormat = new TextFormat;
dateStyle.color = 0xFFFFFF;
dateStyle.size = 48;
dateStyle.font = "myriadMm";
dateStyle.align = "left";
var myTimeTextBox:TextField = new TextField;
myTimeTextBox = new TextField();
myDateTextBox.text = String(days[my_date.day] + "," + " " +
months[my_date.month] +" " + my_date.date + " " + my_date.fullYear);
myDateTextBox.width = 600;
myDateTextBox.x = 70;
myDateTextBox.y = 70;
myDateTextBox.setTextFormat(dateStyle);
//Add it to the stage;
containerStage.addChild(myDateTextBox);
myTimeTextBox.text = String(my_date.hours + ":" + my_date.minutes + " " +
ampm);
myTimeTextBox.width = 600;
myTimeTextBox.x = 70;
myTimeTextBox.y = 117;
myTimeTextBox.setTextFormat(dateStyle);
containerStage.addChild(myTimeTextBox);
//Event Listeners
phone.addEventListener(MouseEvent.CLICK, fl_ClickToGoToAndPlayFromFrame);
function fl_ClickToGoToAndPlayFromFrame(event:MouseEvent):void
trace("directory ready");
simpleGreen.addEventListener(MouseEvent.CLICK,
fl_ClickToGoToAndPlayFromFrame_2);
function fl_ClickToGoToAndPlayFromFrame_2(event:MouseEvent):void
navigateToURL(link, "_self");
videoDirectory.addEventListener(MouseEvent.CLICK,
fl_ClickToGoToAndPlayFromFrame_3);
function fl_ClickToGoToAndPlayFromFrame_3(event:MouseEvent):void
trace("Video Player is Ready");
function textLoaded(evt:Event):void
info_txt.htmlText = textLoader.data;
Mary Crotteau
7. Re: Is it possible to load a URL on stage?
kglad Nov 26, 2013 7:54 AM (in response to EGBAR.Mary)use:
var link: URLRequest = new URLRequest("http://simplegreen.com/");
//ADD CONTAINERS
var containerStage: Sprite = new Sprite();
stage.addChild(containerStage);
//DATE TIMER
var my_date: Date;
var my_timer: Timer = new Timer(1000); //create a new timer that ticks everysecond
var dateStyle: TextFormat = new TextFormat;
var myDateTextBox: TextField = new TextField;
var myTimeTextBox: TextField = new TextField;
my_timer.start();
//MONTH AND DATE
var months: Array = ["Jan", "Feb", "Mar", "Apr", "May", "June", "Jul", "Aug", "Sept", "Oct", "Nov", "Dec"];
var days: Array = ["Sun", "Mon", "Tues", "Wed", "Thurs", "Fri"];
//Text Loader
var textLoader: URLLoader = new URLLoader();
var ampm: String = new String();
function onTimer(e: TimerEvent): void {
myDateTextBox.text = days[my_date.day] + "," + " " + months[my_date.month] + " " + formatF(my_date.date) + " " + my_date.fullYear;
if (my_date.hours < 12) {
ampm = "AM";
} else {
ampm = "PM";
var hours:int = my_date.hours;
if(hours > 12) {
hours-=12;
myTimeTextBox.text = formatF(hours) + ":" + formatF(my_date.minutes) + " " + ampm;
function formatF(n:int):String{
var s:String = n.toString();
while(s.length<2){
s="0"+s;
return s;
//Event Listeners
function fl_ClickToGoToAndPlayFromFrame(event: MouseEvent): void {
simpleGreen.addEventListener(MouseEvent.CLICK, fl_ClickToGoToAndPlayFromFrame_2);
function fl_ClickToGoToAndPlayFromFrame_2(event: MouseEvent): void {
videoDirectory.addEventListener(MouseEvent.CLICK, fl_ClickToGoToAndPlayFromFrame_3);
function fl_ClickToGoToAndPlayFromFrame_3(event: MouseEvent): void {
function textLoaded(evt: Event): void {
8. Re: Is it possible to load a URL on stage?
EGBAR.Mary Nov 27, 2013 7:19 AM (in response to kglad)Thank you so much! One question, the text is not listening to the style. It
displays small and serif.
Mary Crotteau
9. Re: Is it possible to load a URL on stage?
kglad Nov 26, 2013 9:30 AM (in response to EGBAR.Mary)use:
tf.defaultFormat=dateStyle;
10. Re: Is it possible to load a URL on stage?
EGBAR.Mary Nov 26, 2013 12:41 PM (in response to kglad)That didn't work either.
Mary
11. Re: Is it possible to load a URL on stage?
kglad Nov 26, 2013 1:26 PM (in response to EGBAR.Mary)didn't you see an error message???
anway, that should be
tf.defaultTextFormat=dataStyle;
12. Re: Is it possible to load a URL on stage?
EGBAR.Mary Nov 27, 2013 7:05 AM (in response to kglad)Yes!!!!
Thank you sooo much!
myDateTextBox.defaultTextFormat=dateStyle;
13. Re: Is it possible to load a URL on stage?
EGBAR.Mary Nov 27, 2013 7:08 AM (in response to kglad)P.S. Is it possible to remove my phone and address on all the entries on the
thread?
14. Re: Is it possible to load a URL on stage?
kglad Nov 27, 2013 7:21 AM (in response to EGBAR.Mary)you're welcome.
and yes, i removed that info from your messages. (happy holidays to you all up the 405 from me in oc.)
