1 Reply Latest reply on Nov 25, 2013 4:54 PM by Peter Spier
    Indesign Preflight Problem
    waltond1511
      So, I was given a book to proof and send off to be printed. When checking the links every link gives me the error of, "Content generates Cyan, Magenta, or Yellow Plate." How do I solve this problem? I have never even seen this problem in five+ years of indesign use
        • 1. Re: Indesign Preflight Problem
          Are you printing in color?
          This wouldn't necessarily be a fatal error even if you aren't (if you, then of course you need CMY plates) since you can export to a grayscale PDF (if you have CS6 or newer).
          Bottom line is it sounds like you're using a preflight profile designed for a Black ink-only workflow.
