I have a process which at the moment requires me to state the version of the LCA file (currently being hardcoded) this process is currently in. We regularly increment/change the LCA version number as when required and hence when we do so, we would need to manually tweak the value in this process to correspond with the latest LCA version number. With this method, there is the regular risk of forgetting / overlooking stating the correct version of the LCA file in this process.
Is there any activity/ function that we can call to automatically grab the current version of the LCA, a particular process is in?
Thanks.
Views
Total Likes
Is the version number part of the process?
If so, you may use process manager api to query the process properties..
Nith
Views
Total Likes
The version number is part of the LCA application. Is there any 'activity' where I can retrieve that version for use in the process?
Thanks.
Views
Total Likes
