21 Replies Latest reply on Dec 4, 2013 3:47 AM by VDOSurfer
    GoPro MP4 Files
    Brendanj
      Hi
      I am having trouble when rendering Gopro files in Premiere Elements 11 as they degrade and become fuzzy after rendering (they are fine prior to rendering)... any suggestions...?
      Regards Brendan
        • 1. Re: GoPro MP4 Files
          A.T. Romano Level 7
          Brendanj
          What computer operating system is your Premiere Elements 11 running on? What is your video card and is its driver up to date according to the web site of the video card manufacturer?
          What are the properties of your GoPro footage (which GoPro camera)? Video and audio compression, frame size, frame rate, file extension, interlaced or progressive, pixel aspect ratio? Is the footage pre-processed with GoPro software before it is imported into Premiere Elements 11?
          Who is setting the project preset for the project, you or the program? If the program, have you checked to determine if the program set is appropriately? Sometimes it does not and then you have to set the project preset yourself manually via File Menu/New/Project before you import your source media. (Please see Edit Menu/Project Settings/General.)
          Are you using the term "rendering" to refer to
          a. rendering the Timeline content to get the best possible preview in the playback of the TImeline content in the Edit Mode Monitor
          or
          b. render as in export to file saved to hard drive
          If you are referring to render as in export what are you export settings, including those under the Advanced Button/Video Tab Audio Tab of the preset selected?
          Let us start here. We will be watching for your follow up.
          Thanks.
          ATR
          • 2. Re: GoPro MP4 Files
            Brendanj Level 1
            Wow... hard questions for a novice but I'll give them a go
            What computer operating system is your Premiere Elements 11 running on?... Windows 7
            HP Pavillion 520-1040a computer
            Video card - AMD Radeon HD6500a... i have not updated the driver at any time
            Processor - AMD A8-3800
            RAM - 8 gig
            Memory 2TB
            What are the properties of your GoPro footage (which GoPro camera)? Hero 3 Black edition... 1440 48
            Video and audio compression, frame size, frame rate, file extension, interlaced or progressive, pixel aspect ratio? Not sure
            Is the footage pre-processed with GoPro software before it is imported into Premiere Elements 11? I have tried converting the files with the GoPro Cineform software along with importing them direct from the hard drive... the post render deteriation is the same in both cases
            Who is setting the project preset for the project, you or the program? No sure so I suggest the program
            If the program, have you checked to determine if the program set is appropriately? Not sure how to do this
            Sometimes it does not and then you have to set the project preset yourself manually via File Menu/New/Project before you import your source media. (Please see Edit Menu/Project Settings/General.) I'll have a play with this to see if it makes sense to me
            a. rendering the Timeline content to get the best possible preview in the playback of the TImeline content in the Edit Mode Monitor Yes
            or
            b. render as in export to file saved to hard drive I have also tried this but it seems the program renders the time line as part of the export...?
            If you are referring to render as in export what are you export settings, including those under the Advanced Button/Video Tab Audio Tab of the preset selected? Not sure, will try to look
            • 3. Re: GoPro MP4 Files
              A.T. Romano Level 7
              Brendanj
              Thank you. You supplied me with enough information to figure out what we are up against.
              1440p 48 tells me that you are using a GoPro video that is "atypical" for the Premiere Elements project presets among other things. What you have is 1920 x 1440 4:3 @ 48 progressive frames per second. The format includes H.264 video compression and a .mp4 file extension (aka wrapper/container), What does that mean in terms of what you have and what you want as the end product?
              Here is something for us to explore.
              1. Open Premiere Elements 11, go immediately to File Menu/New/Project and in the new project dialog, set the project preset for
              NTSC
              FLIP
              Flip Mino Ultra 30p
              before you exit the new project dialog, please a check mark next to "Force Selected Project Setting on This Project".
              2. In the Premiere Elements workspace, use Add Media/Files and Folders/Projects Assets from where you drag your video to the Expert view Timeline.
              3. When you are ready for export, look at the following to get an AVCHD.mp4 video (1920 x 1440 @ 50 progressive frames per second)
              Publish+Share
              Computer
              AVCHD
              with Presets = MP4 H.264 1920 x 1080 p30
              then under the Advanced Button/Video Tab
              There is no 48 frames per second, so I settled in on 50 progressive frames per second.
              That was just an experiment pending further details from you.
              Please review.
              Thanks.
              ATR
              • 4. Re: GoPro MP4 Files
                A.T. Romano Level 7
                Brendanj
                After all of the above latest post, I forgot to ask "Any particular reason why you selected the 1440p 48 setting for your GoPro recording?
                ATR
                • 5. Re: GoPro MP4 Files
                  Brendanj Level 1
                  ATR
                  I settled on 1440p 48 as it was the highest quality setting... simple as that. Being the novice that I am, do you recommend a different setting...?
                  By the way, I just published a video file and it's perfect...! You are a legend
                  Thanks so much for your help
                  • 6. Re: GoPro MP4 Files
                    A.T. Romano Level 7
                    Brendanj
                    In non technical terms, do not mess with a good thing. That was really great news that the exploration turned out so well.
                    For alternative recording settings, please check out the following
                    http://gopro.com/cameras/hd-hero3-black-edition#technical-specs
                    first 1080p (1920 x 1080 @ 29.97 progressive frames per second or whatever the frame rate is for your set up NTSC 29.97 vs PAL 25)
                    We will be watching for your progress in the morning. We can discuss alternative recording settings and assocated Premiere Elements export settings when you are ready. Great job.
                    ATR
                    • 7. Re: GoPro MP4 Files
                      Brendanj Level 1
                      Hi Atr
                      Need a heads up... I dragged the published file on to a flash card to play on my TV but it does work.... it recognises the USB card but wont recognise the file, any clues...?
                      • 8. Re: GoPro MP4 Files
                        A.T. Romano Level 7
                        Brendanj
                        I would have thought that the USB Flash Drive with the  AVCHD.mp4 file would have played back, but....
                        1. What type of player was this - DVD or Blu-ray connected to the TV?
                        2. If the USB Flash Drive is recognized, it is probably formatted as FAT32 which is seen as a recommended format for the USB Flash Drive in cases such as these.
                        3. If you have not already, check the user manual for the player to confirm its support specifications.
                        4. If all else fails, have you tried a HDMI connection for computer to TV?
                        5. We could look at
                        Publish+Share
                        Computer
                        QuickTime
                        with Presets = NTSC DV 16:9, and, under the Advanced Button/Video Tab, set for
                        This will give you a H.264.mov file version. Leave the bitrate option as is for now if you try this as an alternative format on the USB Flash Drive.
                        More later.
                        ATR
                        • 9. Re: GoPro MP4 Files
                          Brendanj Level 1
                          AT
                          I know we're close to getting it sorted... I'll try the settings as per
                          your email and see how it goes
                          The edited .mp4 plays perfectly on my computer when I publish it but when
                          I put the .mp4 file on a USB stick and plug it directly into the TV (tv is
                          only 18 months old) the file comes up with an error. I have played other
                          .mp4 files without issue on the tv... ones I have used the Gopro Cineform
                          software to produce so I know it's not the tv
                          I'll have another play with it later in the day and let you know how I go
                          Regards
                          Brendan McMahon
                          General Manager – Region V1
                          MM Electrical Merchandising
                          ( 03 9839 4888
                          7 03 9764 3633
                          ( 0408 855 292
                          Business Registration Number 0377700X
                          ü www.mmem.com.au
                          Note:
                          The information contained in this electronic email message is privileged
                          and confidential, and is intended only for the use of the addressee.
                          If you are not the intended recipient, you are hereby notified that any
                          disclosure, reproduction, distribution or other use of this communication
                          is strictly prohibited. If you have received this communication in error,
                          please notify the sender by reply transmission and delete the message
                          without copying or disclosing it.
                          • 10. Re: GoPro MP4 Files
                            A.T. Romano Level 7
                            Brendanj
                            To avoid nuisances best remove the contact information in your latest post in your thread.
                            We will be looking forward to your results.
                            Thanks.
                            ATR
                            • 11. Re: GoPro MP4 Files
                              the_wine_snob Level 9
                              Brendanj,
                              I agree with ATR. As the Adobe Forums are open, there are spam'bots crawling around, just looking for e-mail addresses, and any other personal data. It appears that you replied via a POP client, or similar, and that a signature was added. If you would like, we can remove that personal data, to protect your privacy, and I recommend doing so. Just let us know if it's OK to remove it.
                              • 12. Re: GoPro MP4 Files
                                Brendanj Level 1
                                Sounds like a good idea Bill... not sure how to remove it though... any help appreciated
                                • 13. Re: GoPro MP4 Files
                                  Brendanj Level 1
                                  ATR
                                  Still having issues with playing the files on a tv from a USB card... error messagr is "video codec not supported"whatever that means. Don't think its the tv as its a pretty new LED flat screen... any suggestions...?
                                  Regards Brendan
                                  • 14. Re: GoPro MP4 Files
                                    A.T. Romano Level 7
                                    Brendanj
                                    Video codec not supported means that the player is not compatible with the video compression used in the file. Sometimes these error messages are generic rather than specific, but for now we will take them as written.
                                    Have you had the opportunities to check with the user manual for the player to see if its specifications define video compressions as well as file extensions supported when the media is a USB Flash Drive?
                                    In the prior test, we would have offered to it AVCHD (MP4 AVCHD.264) as the .mp4 and H.264 as the .mov.
                                    Have mention the name of the TV device involved? If not, I also can be looking for specifications that can direct us in the specifics of what you have.
                                    More later.
                                    Thanks.
                                    ATR
                                    • 15. Re: GoPro MP4 Files
                                      Brendanj Level 1
                                      I'll have a look at this tonight and see if I can find out the relative
                                      info on the TV (Samsung Digital)
                                      I have used a number of different settings when publishing it... a bit of
                                      trial and error really, but I haven't had success yet
                                      Thanks again for the help
                                      Regards Brendan
                                      • 16. Re: GoPro MP4 Files
                                        A.T. Romano Level 7
                                        Brendanj
                                        Does this Samsung Digital have the USB port into which you insert the USB Flash Drive with your video?
                                        ATR
                                        • 17. Re: GoPro MP4 Files
                                          Brendanj Level 1
                                          Yes it does
                                          • 18. Re: GoPro MP4 Files
                                            A.T. Romano Level 7
                                            Brendanj
                                            I came across this Samsung article with some details that look interesting
                                            TVs" What Media Play Functions Does The USB Port Support?
                                            http://www.samsung.com/us/support/faq/FAQ00000457/625/
                                            I could suggest Premiere Elements settings but they will not match the properties of your source video 1920 x 1440 @ 48 progressive frames per second. We came close to that with the exports that I suggested 1920 x 1440 @ 50 progressive frames per second (AVCHD.mp4 or H.264.mov), but those will not playback from USB Flash Drive for you. In the search for other, that 1920 x 1440 is a deal breaker in finding export settings for alternative video compression.
                                            Any chance you shooting in 1920 x 1080p30? Or, even 1920 x 1080i30?
                                            ATR
                                            • 19. Re: GoPro MP4 Files
                                              Brendanj Level 1
                                              ATR
                                              Yep... can shoot in 1920 x 1080p30... as I said, the only rationale for
                                              1920 x 1440 is that it's the highest setting and I assumed it would
                                              produce the best results. I'm afraid I just a "point & shoot" novice and
                                              the tech stuff gives me grief...!
                                              I'm pretty sure I can use the Gopro software to put the latest clips
                                              together and then move to the Premiere Elements from this point forward
                                              I don't suppose I could use the Premiere Elements software and then burn
                                              the files to DVD and play them that way...?
                                              Regards
                                              Brendan McMahon
                                              • 20. Re: GoPro MP4 Files
                                                A.T. Romano Level 7
                                                Brendanj
                                                How about we try this. You shoot 1920 x 1080 @ 29.97 progressive frames per second.
                                                Premiere Elements 11.
                                                Make sure that the project preset is
                                                NTSC
                                                DSLR
                                                1080p
                                                DSLR 1080p30 @ 29.97
                                                (1) Then when you get to Publish+Share
                                                Publish+Share
                                                Disc
                                                DVD, disc
                                                and use the preset for NTSC_Widescreen Dolby DVD.
                                                (2) Then when you get to Publish+Share
                                                Publish+Share
                                                Computer
                                                MPEG
                                                and use Presets = HD 1080p 29.97 High Quality
                                                (do not change any settings under Advance Button/Video Tab and Audio Tab)
                                                See what this one looks like on the computer playback but also on your TV via USB.
                                                Let see what we have here. I am hoping that the MPEG2.mpg will be a winner for the TV viewing via USB Flash Drive.
                                                ATR
                                                • 21. Re: GoPro MP4 Files
                                                  VDOSurfer Level 3
                                                  Agree with ATR that MPEG2 is more readily supported than H264 on TVs. I am hoping for success from OP too!
