1 Reply Latest reply on Nov 26, 2013 1:48 AM by sjpt
    I have old ebooks (different formats)
    caguas1947
      I have quite a few e-books, which I would like to read.   there in LIT(From Microsoft Reader), and Epub (from Fictionwise).
      Can these formats be transferable to ADE?
      The fictionwise e-books are very rare.
      thanks
        • 1. Re: I have old ebooks (different formats)
          sjpt Level 4
          If they are not DRM then use the free Calibre to convert them to whatever is convenient.
          http://calibre-ebook.com/
          You'll also probably find Calibre much better than ADE for all non-DRM book tasks (reading, transferring, managing, converting, etc)
          The .epub files should be readable on ADE even if DRM; reading DRM .epub files is really what ADE is for.
          I'm almost certain ADE cannot read .LIT files.
          You may be able to remove DRM from .lit files using a DRM stripper such as epubee.
          I do NOT advocate using such code to get around the valid limitations placed on a DRM book.
          However, where the problem arises only because problems with DRM infrastructure and its implementation, such a measure is totally justifiable.
          As the .lit format appears to be deprecated, that may well justify the use of such code.
