0 Replies Latest reply on Nov 26, 2013 6:36 AM by R Scott 31
    LiveCycle ES4 Output Watermark Transparency Warning
    R Scott 31
      Hello,
      I am running into a warning during my PDF assembly and output process.  The warning seems to exist for every page of the PDF document having a watermark.  Here is the logging entries that can be found in the server.log file on our output server.  Is there a way in the administration UI to set transparancy that I may have missed, a server configuration that needs to be updated, or is this something that needs to occur on the LC Designer side?  Any feedback would be appreciated.  Thanks!  Richard
      2013-11-26 08:59:16,516 INFO  [com.adobe.livecycle.assembler.AssemblerServiceImpl] (http-0.0.0.0-8080-20) ALC-ASM-N00-001: Execute: invoke() begin on thread http-0.0.0.0-8080-20 18278
      2013-11-26 08:59:16,578 INFO  [com.adobe.internal.ddxm.Executive] (http-0.0.0.0-8080-20) DDXM_N00000: Started processing result named Return.pdf
      2013-11-26 08:59:16,731 WARN  [com.adobe.internal.pdfm.content.FormXObjectService] (http-0.0.0.0-8080-20) PDFM_W06008: The Watermark request requires transparency; distortions in the colors may occur.
      2013-11-26 08:59:16,734 WARN  [com.adobe.internal.pdfm.content.FormXObjectService] (http-0.0.0.0-8080-20) PDFM_W06008: The Watermark request requires transparency; distortions in the colors may occur.
      2013-11-26 08:59:16,750 WARN  [com.adobe.internal.pdfm.content.FormXObjectService] (http-0.0.0.0-8080-20) PDFM_W06008: The Watermark request requires transparency; distortions in the colors may occur.
      2013-11-26 08:59:16,751 WARN  [com.adobe.internal.pdfm.content.FormXObjectService] (http-0.0.0.0-8080-20) PDFM_W06008: The Watermark request requires transparency; distortions in the colors may occur.
      2013-11-26 08:59:16,769 WARN  [com.adobe.internal.pdfm.content.FormXObjectService] (http-0.0.0.0-8080-20) PDFM_W06008: The Watermark request requires transparency; distortions in the colors may occur.
      2013-11-26 08:59:16,770 WARN  [com.adobe.internal.pdfm.content.FormXObjectService] (http-0.0.0.0-8080-20) PDFM_W06008: The Watermark request requires transparency; distortions in the colors may occur.
      2013-11-26 08:59:16,771 WARN  [com.adobe.internal.pdfm.content.FormXObjectService] (http-0.0.0.0-8080-20) PDFM_W06008: The Watermark request requires transparency; distortions in the colors may occur.
      2013-11-26 08:59:16,772 WARN  [com.adobe.internal.pdfm.content.FormXObjectService] (http-0.0.0.0-8080-20) PDFM_W06008: The Watermark request requires transparency; distortions in the colors may occur.
      2013-11-26 08:59:16,773 WARN  [com.adobe.internal.pdfm.content.FormXObjectService] (http-0.0.0.0-8080-20) PDFM_W06008: The Watermark request requires transparency; distortions in the colors may occur.
      2013-11-26 08:59:16,774 WARN  [com.adobe.internal.pdfm.content.FormXObjectService] (http-0.0.0.0-8080-20) PDFM_W06008: The Watermark request requires transparency; distortions in the colors may occur.
      2013-11-26 08:59:16,791 INFO  [com.adobe.internal.ddxm.Executive] (http-0.0.0.0-8080-20) DDXM_N00001: Successful assembly of result named Return.pdf
      2013-11-26 08:59:16,794 INFO  [com.adobe.livecycle.assembler.AssemblerServiceImpl] (http-0.0.0.0-8080-20) ALC-ASM-N00-001: Execute: invoke() end on thread http-0.0.0.0-8080-20 18278
