Robohelp 9
Word 2010
I have a merged project with two child projects. The first child has been in the parent project and working fine for different generated outputs. I regulary swop out different child projects to generate cusotm output compilations with no problem.
Created a new child project and added this to the Parent TOC but the output does not display the second child TOC items in the TOC.
Any ideas welcome
Have you regenerated the parent since adding the TOC.
BTW. You don't need to swap children in and out. Have one merge with all the required children. Copy the folder with all the generated outputs and then delete the children not required.
Oops!, schoolboy error. I think i have done this before:
Child project has a build number in the name. I used hyphens for the project name in between the build numbers but dots between the build numbers in the child project generate path.
Sorry for the confusion and thanks for the lightning fast response.
