0 Replies Latest reply on Nov 26, 2013 8:36 AM by Riccardo Giaconia
    PDF Creation gets slower and slower
    Riccardo Giaconia Level 1
      I have designed a simple process to create PDFs from XML files. The problem is the PDF creation gets slower and slower over time.
      The process is designed like this:
      1) loop on a source XML directory (it contains 3000 XMLs),
      2) read (using Read Document activity) the n-th XML file,
      3) run a subprocess that creates a PDF (using generatePDFOutput activity) and save it to the filesystem,
      4) and so on for every XML inside the source directory.
      The main process inputs are:
      1) source XML directory path (e.g. C:\my_xmls)
      2) destination PDF directory path (e.g. C:\my_pdfs).
      At the end of the process I get these results:
      1) first 1000 PDFs created in about 8-10 minutes
      2) second 1000 PDFs created in about 12-15 minutes
      3) last 1000 PDFs created in about 20-25 minutes
      I cannot use Watched Folders for several reasons but above all:
      1) every 500 PDFs the process sends an email,
      2) the source XML directory path may change over time.
      Why do the process gets slower and slower?
      I use LiveCycle ES 3.
      CreatePDF_from_directory:
      CreatePDF:
