1 Reply Latest reply: Nov 26, 2013 11:42 AM by Danny Occoquan RSS
    How can I manipulate structure tags in LiveCycle XML form
    Danny Occoquan Community Member
      Have a form that was created in LiveCycle by another company.
      Need to make it a flat, tagged, PDF, i.e., to look like the form but not have actual fields.
      It has structure tags, but they're not acceptable, and in Acrobat I'm unable to manipulate them.
      When I go to LiveCycle and look at PDF Structure tags, it just has this message: "PDF Structure can only be used in PDF forms that contain artwork."
      When I try to optimize the form fields away in Acrobat, it says "This PDF document contains an Adobe XML form. Such files cannot be optimized"
      Any ideas?  Thanks in advance!
        • 1. Re: How can I manipulate structure tags in LiveCycle XML form
          Had to keep moving with this, hopefully someone will come up with a better solution, here's how I got a flat PDF: saved the form as encapsulated postscript, then in Windows Explorer right-clicked on the *.eps files and converted to PDF ... had to delete the useless tags that were created during that process, retagging manually ... but it's giving me what I need. I was surprised at no loss of resolution, and all the text is taggable.
