3 Replies Latest reply on Nov 28, 2013 10:36 PM by radzmar
    Can you add bookmarks to a PDF Package of Dynamic Forms?
    mtettenhorst
      I have created a PDF package consisting of separate dynamic forms created in LiveCycle.  The documents have been saved as 'enable user rights' and as read only, allowing them to save their own copy but not to write over the original form on our intranet.  Currently, the package opens with a navigation panel and visible thumbnails.  I prefer to use the bookmark view.  However, when I try to manually create a bookmark, I get the following error -
      "This document restricts some Acrobat features to allow for extended features in Adobe Reader.  To create a copy of the document that is not restricted (and has no extended features in Adobe Reader), click Save a Copy"
      Any ideas on how to fix?
      Thanks!
        • 1. Re: Can you add bookmarks to a PDF Package of Dynamic Forms?
          jasotastic81 Level 3
          OK, I think I follow what's happening. You want to modify a document that was saved in Acrobat with an extension. You open it in LiveCycle and get that error message. That's alright, probably. It's very similar to the error I get on ES2: "Some usage rights have been applied to the form you want to open. Opening the form will remove the usage rights. Do you want to continue?"
          Try this and see if it works. Open the document in LiveCycle (you may have to "save as..." like it says), and make your modifications. Then save the document. Open the document in Acrobat and Save As > Adobe Extended PDF... or whatever the menu option is, now. (I think it changed slightly after a recent update.)
          • 2. Re: Can you add bookmarks to a PDF Package of Dynamic Forms?
            mtettenhorst Level 1
            My apologies, here is a bit more of the background.  I created two separate documents in LiveCycle.  Both documents are dynamic forms with expanding text boxes.  Originally, the forms were in an Excel workbook and you could tab to either form (as someone might use one or the other, or both).  To mimic the nature of the Excel workbook, I have packaged these two dynamic forms into one PDF package so that it is able to be viewed using only Adobe Reader.  The intent was to create bookmarks so that the user could still tab to one document or the other.  I was attempting to create the bookmarks in the user PDF version and it was not allowing me to.  Does this clarify?
            • 3. Re: Can you add bookmarks to a PDF Package of Dynamic Forms?
              radzmar Adobe Community Professional & MVP
              You can try to add the bookmarks in Acrobat before you save the package as Reader Extended file.
              But I don't know, if the bookmarks will work, because the targets in a dynamic form does not exist as long the file has not been opened.
