1. Re: RH10 Webhelp and IE11
Willam van Weelden Nov 27, 2013 12:34 AM (in response to Montage9)There have indeed been other posts in IE11 problems. The strange thing
is that if I try an RH10 output on a webserver, it all seems to work. So
I'm wondering if this could be releated to security settings for
intranets and local files.
Can you open the console with F12 and see what error messages pop up?
Greet,
Willam
2. Re: RH10 Webhelp and IE11
Jeff_Coatsworth Nov 27, 2013 5:48 AM (in response to Montage9)Did you add the “meta tag fix” (meta http-equiv="X-UA-Compatible" content="IE=EmulateIE8) that forces it to emulate IE8?
3. Re: RH10 Webhelp and IE11
Jeff_Coatsworth Nov 27, 2013 5:48 AM (in response to Willam van Weelden)I know that in IE10 I had to add my intranet LAN server to the “Trusted Locations” list to get it to work – probably the same in IE11.
4. Re: RH10 Webhelp and IE11
Montage9 Nov 27, 2013 3:36 PM (in response to Willam van Weelden)William
Thx for the response.
I can open the console in IE but am not familiar with this. If I select the "Console" tab it tells me that JavaScript Console is attached and accepting commands. There are zero 'white cross in red circle' and zero 'exclamation mark in orange triangle'.
What everything else means here is gobbledygook to me!
5. Re: RH10 Webhelp and IE11
Montage9 Nov 27, 2013 3:48 PM (in response to Jeff_Coatsworth)Jeff
"meta tag fix" ?????? No idea what this is. My version of RH10 has all the Adobe recommended fixes applied. The published help project has been working fine for users of IE10 for some while now. Problems only started occurring when Windows Update automatically installed IE11 on their server and workstations - these problems only arose at this point, which would indicate to me that IE11 is the problem rather than anything RH10 is (or isn't) doing.
After applying the Adobe supplied fix for IE10 to RH10 all the published webhelp appeared to be working fine in IE10. Applying the whproxy.js fix from Adobe then resolved the Google Chrome update problem.
No one appears to have needed to add their intranet to Trusted Locations.
Overnight it has been reported that users who had installed IE11 and experienced problems, having reverted back to IE10, now no longer have any problems with the RH10 WebHelp output.
Again, this would indicate to me that the problem is that something has changed in IE11 that RH10 needs to address (similar to the Google Chrome issue recently).
6. Re: RH10 Webhelp and IE11
Jeff_Coatsworth Nov 28, 2013 5:18 AM (in response to Montage9)I was referring to this thread’s fix - http://forums.adobe.com/message/5765240#5765240
What you’ve indicated happening needs to be submitted as a bug report to Adobe – just talking about it here on the forums doesn’t get it on their radar. Use this site: https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
7. Re: RH10 Webhelp and IE11
Montage9 Nov 28, 2013 2:10 PM (in response to Jeff_Coatsworth)Jeff
Thx for the response. I have submitted this as a bug report to Adobe and received the following response:
"Thanks for reaching out to us. We are aware of this problem and have been working on it. IE is trying to be more standards compliant with IE11 version but it hasn't implemented all the standards components which other browsers provide. This is impacting our progress but we are seeing how best to creatively circumvent the issues."
Have advised users to use Firefox, Chrome or IE10 until a fix for the IE11 issue is released.
8. Re: RH10 Webhelp and IE11
Timothy DM Dec 2, 2013 9:35 AM (in response to Montage9)Just downloaded IE 11 and tested webhelp project. Experienced same issues reported by Montage9 above. Used IE11 F12 to view settings. Found Document mode set to "Edge (Default)". Changed this one setting to use "10". WebHelp folder worked correctly again (with exceptions noted in a previous post regarding unresolved issues in IE10).
IE 11 includes documentation on edge mode (http://www.modern.ie/en-us/f12) and encourages designers to begin web pages with the doctype html tag. RH pages begin with an xml tag. Not sure if this matters, but passing it along in hopes that RH developers will take a look at getting webhelp to work in IE 11's edge mode.
9. Re: RH10 Webhelp and IE11
sumaya77 Aug 19, 2014 10:19 PM (in response to Timothy DM)I just tried your fix, and it worked! However, I didn't know how to save the Document to 10 instead of Edge, so when I closed the F12 window, the webhelp reverted back to not showing the TOC. How do you make the fix permanent?
10. Re: RH10 Webhelp and IE11
Willam van Weelden Aug 20, 2014 4:30 AM (in response to sumaya77)You need to add the meta tag for document mode to your output. The easiest way to do this is to use a find and replace operation to add it to your output.
For more information on the meta tag, see http://msdn.microsoft.com/en-us/library/ff955275(v=vs.85).aspx
Kind regards,
Willam
