• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Updated Java
New Here ,
Nov 27, 2013 Nov 27, 2013
I am trying to use a jdbc/mysql connector. The issue is that the connector is compiled in a later version that what is installed in Coldfusion MX 6.1. I have downloaded and installed the Java 6 SE JDK and installed it. Here is my JVM config file.
# VM configuration
# Where to find JVM, if {java.home}/jre exists then that JVM is used
# if not then it must be the path to the JRE itself
#java.home=C:/Program Files (x86)/Java/jdk1.6.0_45/jre
#java.home=C:\\Program Files (x86)\\Java\\jdk1.6.0_45\\jre
java.home=C:/CFusionMX/runtime/jre
# If no java.home is specified a VM is located by looking in these places in this
# order:
#  1) bin directory for java.dll (windows) or lib/<ARCH>/libjava.so (unix)
#  2) ../jre
#  3) registry (windows only)
#  4) JAVA_HOME env var plus jre (ie $JAVA_HOME/jre)
# Arguments to VM
java.args=-server -DJINTEGRA_NATIVE_MODE -DJINTEGRA_PREFETCH_ENUMS -Xmx512m -Dsun.io.useCanonCaches=false -Xbootclasspath/a:"{application.home}/../lib/webchartsJava2D.jar" -XX:MaxPermSize=128m -XX:+UseParallelGC
# commas will be converted to platform specific separator and the result will be passed
# as -Djava.ext.dirs= to the VM
java.ext.dirs={jre.home}/lib/ext
# where to find shared libraries
java.library.path={application.home}/../lib,{application.home}/../jintegra/bin,{application.home}/../jintegra/bin/international,{application.home}/../lib/_nti40/bin
system.path.first=false
# JVM classpath
java.class.path={application.home}/servers/lib,{application.home}/../lib/cfusion.jar,{application.home}/../lib,{application.home}/../runtime/lib/jrun.jar,{application.home}/../runtime/lib,
I have tried each of the 4 paths and only the last one works. The following is my Coldfusion error log.
Error loading: C:/Program Files (x86)/Java/jdk1.6.0_45/jre\bin\server\jvm.dll
Error loading: C:\Program Files (x86)\Java\jdk1.6.0_45\jre\bin\server\jvm.dll
Error loading: C:/Program Files (x86)/Java/jdk1.6.0_45\jre\bin\server\jvm.dll
I have no idea why the jvm.dll can not be found as the file is in that directory.
Views
374
Translate
Translate
Report
Report
Community guidelines
community guidelines
no replies
Have something to add?
Join the conversation
Resources
Documentation
