9 Replies Latest reply on Jan 7, 2014 9:54 PM by Arvindkmar
    Script to search for text and remove hyperlink and characterstyle that is applied (return to normal)
    Soteriologist
      I need help with my script to search for text and remove hyperlink and characterstyle that is applied (return the text to normal).
      I can't get it to do either the way I want.  I want the user to be able to type into a dialog the text they want to search for, have it search for that text IGNORING case (case-insensitive) and then for all the occurences that it finds it, remove the character styles that are applied to it (set it to [None]) and remove the hyperlinks.
      My code seems to set the character style to [None], when I click on the text and look at the Character Styles Window, BUT all the old styles (font color, underline) are still applied to it and not stripped away as I want.
      Also, I can't seem to figure out how to remove all the old links.
      Here's my code:
      var myDocument = app.activeDocument;
      var noneStyle = myDocument.characterStyles.item("[None]");
      var myFindVal = "";
      var myErrorText = "";
      var myErrorCount = 0;
      var myDialog = app.dialogs.add({name: "Search for the user submitted text and remove hyperlinks from found items.", canCancel: true});
      with(myDialog) {
          with(dialogColumns.add()) {
              with(borderPanels.add()) {
                  staticTexts.add({staticLabel: "Search and remove hyperlinks for:"});
                  var myTextBox = textEditboxes.add({minWidth:100});
      if (myDialog.show() == true) {
          myFindVal = myTextBox.editContents;
          doSearchAndReplace();
          app.findTextPreferences = NothingEnum.nothing;
          app.changeTextPreferences = NothingEnum.nothing;
          if (myErrorCount == 0) {
              alert("Done! Part hyperlinks have been removed for: '" + myFindVal + "'!");
          else {
              alert("Last Error Message: '" + myErrorText + "' & Error Count: " + myErrorCount);
      myDialog.destroy();
      function doSearchAndReplace() {
          app.findTextPreferences.findWhat = myFindVal;
          app.findChangeTextOptions.caseSensitive = false;
          app.findChangeTextOptions.includeFootnotes = false;
          app.findChangeTextOptions.includeHiddenLayers = false;
          app.findChangeTextOptions.includeLockedLayersForFind = false;
          app.findChangeTextOptions.includeLockedStoriesForFind = false;
          app.findChangeTextOptions.includeMasterPages = false;
          app.findChangeTextOptions.wholeWord = false;
          var myFoundItems = myDocument.findText();
          for (i = 0; i < myFoundItems.length; i++) {
              myRemoveHyperlinkAndStyle(myFoundItems[i]);
      function myRemoveHyperlinkAndStyle(myFoundItem) {
          try {
              myDocument.hyperlinkTextDestinations.item(myFoundItem).remove();
              myDocument.hyperlinkTextSources.item(myFoundItem).remove();
              myDocument.hyperlinkURLDestinations.item(myFoundItem).remove();
             myFoundItem.applyCharacterStyle(noneStyle);
          catch(myError) {
              myErrorCount++;
              myErrorText = myError;
