1. Re: Folio Overlay is Missing! InDesign CC won't update..?
Peter Spier Nov 27, 2013 1:13 PM (in response to alyweir)I've moved this from the InDesign forum to DPS...
2. Re: Folio Overlay is Missing! InDesign CC won't update..?
Bob Levine Nov 27, 2013 1:30 PM (in response to alyweir)Scrolling text does not work in a PDF, only DPS which is why Peter moved this here. Check under help>updates to see if you're prompted to install the DPS Desktop Tools.
3. Re: Folio Overlay is Missing! InDesign CC won't update..?
clmurphy Nov 5, 2014 1:26 PM (in response to alyweir)Same thing happening to me. JUST downloaded new InDesign CC. Folio Overlay missing. In Fact, I cannot even sign into Folio Builder because it says it needs says "A software update is required to use Digital Publishing Suite. Please go to the Help menu and select Updates to get the required software." However, InDesign is completely up to day (I just downloaded it), the CC installer says it is up to date, AND there is NO "Updates" in the Help menu. I am not sure what 'Update" the Folio needs.
4. Re: Folio Overlay is Missing! InDesign CC won't update..?
fohara Nov 5, 2014 1:44 PM (in response to clmurphy)I am having the same issue as clmurphy where it says i need an update but update is all grayed out. when i try downloading what i think i need directly from web it says "update failed. please contact your administrator if you wish to make updates to your machine. Updates have been suppressed by the Administrator"
anyone have a solution?
5. Re: Folio Overlay is Missing! InDesign CC won't update..?
Bob Levine Nov 5, 2014 2:11 PM (in response to fohara)Try trashing your preferences and then try again.
6. Re: Folio Overlay is Missing! InDesign CC won't update..?
fohara Nov 6, 2014 5:57 AM (in response to alyweir)Bob Levine... Preferences? System or Indesign Preferences??
Do you mean System > Library > Preference Panes??
Thanks for the help.
